11-17-2013, 12:29 PM | #1 |
Newbie Join Date: Mar 2013 Location: Sandy
| Novak Goat 3s question
I have a Goat 3s. I am running a 3s battery. When I turn it on it works for a short period then glitches and all of the LED's turn on and I loose all operation. After I let it sit for a few minutes it all comes back then repeats itself. I do not have a BEC connected and can not find anything about all LED's nor anything that says a BEC is required. Please help.
11-17-2013, 12:57 PM | #2 |
| Re: Novak Goat 3s question
What rig? What motor? What servo? Did you calibrate the ESC to the RX? From this.... http://teamnovak.com/file_download/1...3S%20Instr.pdf I don't see "all LED's" on. |
11-17-2013, 02:14 PM | #3 |
It is installed in an SCX10 it is the Goat 3s with a 3s 2200 Lipo. Servo is an ALINE 166 oz servo. Motor is 18.5 censored ballistic. Directions were followed to a T. (Multiple times) it has the fan installed. The same issue will also happen if I turn it on and it just sits there inactive. Not sure what all LEDs stand for. It will flicker them then turn them on solid and bam nothing. I touch the speed control and it is cool to the touch.
11-17-2013, 07:41 PM | #4 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
Does the light change when your hit the trigger forward or reverse ?
11-17-2013, 10:57 PM | #6 | |
Rock Stacker Join Date: Oct 2013 Location: Cotati, California
| Re: Novak Goat 3s question Quote:
Also note: If you change settings on your transmitter you must repeat one-touch programming. Source: Goat 3s Installation Guide | |
11-17-2013, 11:15 PM | #9 |
Novak is pretty chill from what I've seen. They replaced my friends timbuk2 combo that burned up in just under a week and a half. If you've done everything you can do and it's still misbehaving you'll need to send it in. I'm pretty sure they'll set you up with something comparable if not better since the Goat3s is discontinued. Hey, you may even get an Eiger Pro! |
11-18-2013, 01:41 AM | #11 | |
Novak Goat 3s question - Similar Threads | ||||
novak goat 3s question? | ryno mike | Electronics | 3 | 04-01-2012 07:21 AM |
Novak Goat 3S question | Kage | Electronics | 3 | 12-20-2010 10:36 AM |
Novak Goat Question(s) | smm_cbf | Electronics | 2 | 05-29-2009 06:26 PM |
question about novak goat bec | Farmer | General Crawlers | 4 | 05-27-2008 04:51 PM |
Novak Goat Question | darkstar | Electronics | 18 | 05-17-2008 08:24 AM |
