Thread: Brushed on a brushless esc
Old 10-20-2013, 08:00 AM   #1
Exclamation Brushed on a brushless esc
I need help on getting my Novak Timbuk2 Brushless ESC to wor with my Team Teken brushed 35t
minicooperzoom is offline   Reply With Quote
Old 10-20-2013, 08:12 AM   #2
Default Re: Brushed on a brushless esc
Brushless ESC won't run a brushed motor.
Brushed ESC won't run a brushless motor.
Dual type ESC (Castle Creations Mamba Max Pro as an example) can run either type motor, but needs to be set for the motor type.
Charlie-III is offline   Reply With Quote
Old 10-20-2013, 07:10 PM   #3
Would there be a way to program my esc to run a brushed esc.
Old 10-20-2013, 07:19 PM   #4
Suck it up!
Duuuuuuuude's Avatar
Go to Novaks site. Read the specs for the esc in question. If it does not mention being able to run a brushed motor, then it cannot.
Duuuuuuuude is offline   Reply With Quote
Old 10-20-2013, 08:22 PM   #5
Yes, there is a way.......Not by programming thou....
Sell it and get a MMP or Tekin RS...
Colgout is offline   Reply With Quote
Old 10-20-2013, 08:49 PM   #6
ZiG
Well, no, you can probably program it. All you need to do is crack open the case, find the processor, identify the connections you would need to take a serial connection to it, write new firmware and flash it!
ZiG is offline   Reply With Quote
Old 10-21-2013, 06:05 AM   #7
Can the castle creations sidewinder 3 run a brushesd motor? Does the team tenkin 35t hand wound brushed motor need to be broken in? If so how would be the best way to do that?
Old 10-21-2013, 07:26 AM   #8
Can the castle creations sidewinder 3 run a brushed motor? Does the team Tekin 35T hand wound brushed motor need to be broken in? If so how would be the best way to do that?
Instead of us answering some of these questions, why don't you research the ESC's you're interested in? If something does not make sense, then ask.
As to breaking in the 35T motor, running it at light load on ~5 volts for 5 minutes is fine. You can also do it in the rig, keep the throttle at ~1/2 for 5 minutes to let the brushes seat.
DON'T use a "water break-in".
Holmes & Br00d motors come already broken in.
Old 01-15-2014, 07:33 PM   #9
How Do i Maintain a 1978 Tamiya silver can brushed motor? Help would be much appreciated.
Tags
electronics, problem
Brushed on a brushless esc - Similar Threads
brushless esc with brushed motor? The-Blacksheep Axial SCX-10 5 01-03-2012 04:07 PM
Novak Releases "The Goat" brushed/brushless esc and sintered brushless motor Rockpiledriver Electronics 70 09-26-2007 05:59 PM
Brushless esc with a brushed motor ??? eric113 Electronics 12 10-01-2006 04:56 PM
