01-20-2014, 03:02 PM | #1 |
Quarry Creeper Join Date: May 2012 Location: Biloxi
| LED Resistor Question
I do marine electronics for a living. I install and wire up equipment. I don't play with circuit boards. I install a lot of LEDs but ive never wired up my own. I drew up a quick schematic of what im trying to accomplish. I want 4 LEDs. 3 will be suffice if need be. Below is a link of the LEDs I want to use. I don't know what resistor I need. Cool White 5050 SMD LED | Surface Mount (SMD) | Component LEDs | Super Bright LEDs |
01-20-2014, 03:19 PM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: LED Resistor Question
I've always used these calculators with mine. Just enter the required values and it should give you the correct resistor. Single Serial/Parallel |
01-20-2014, 05:21 PM | #3 |
Thanks. I'll try it out later tonight when I can sit down with the computer instead of my phone. The whole forward voltage, reverse voltage, voltage drop thing just confuses me.
01-20-2014, 08:47 PM | #4 |
So... Heres the plan. Minus one led in the diagram. 4 would require 3 in series and 1 parallel with 2 resistors. 3 is much easier. the light bar will probably end up with 3 wires coming out of it. one center and one on each side. 1 pos, 2 neg = 2 resistors. I took a picture of the laptop screen. Bad. I know. You get the idea though. Last edited by Hulldiver; 01-20-2014 at 08:55 PM. |
01-20-2014, 08:55 PM | #5 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
You can't do that kind of wiring for a 3S, 11.1V pack. According to your link, each of the LED you are using is 3.2V, 20mA. If you wire them in series, that's already a need for 3.2x4=12.8V which you can't supply with a 11.1V pack under load. You can use 3 LEDs in series: 3.2x3=9.6V 11.1-9.6=1.5V difference. Ohm's law V=IR, 1.5V=0.02mA x ?, so your resistor is 75 ohm or thereabouts. Since you want 6 LEDs, you can construct two sets of 3 LEDs wired in series with the 75 ohm resistor. Then just wire the two sets in parallel. (pos) - LED1 - LED2 - LED3 - 75ohm - (neg) (pos) - LED4 - LED5 - LED6 - 75ohm - (neg) Last edited by Kingmeow; 01-20-2014 at 08:59 PM. |
01-20-2014, 08:57 PM | #6 |
Right. I went ahead and figured for 12.5v, full charge, id rather it be a little dim than burnt. You pretty much hit the nail on the head though.
LED Resistor Question - Similar Threads | ||||
LED voltage/resistor calculation | ik632 | Electronics | 7 | 01-30-2012 03:48 PM |
resistor question | BigSki | Electronics | 2 | 05-08-2011 09:47 PM |
LED question | trost | Chit Chat | 7 | 03-28-2011 12:56 AM |
Another resistor ??? | 86 Iroc | Electronics | 3 | 12-22-2009 07:27 AM |
LED: on which side do you put the resistor? | schlabinski | Electronics | 5 | 03-20-2007 12:15 AM |
