Thread: Mamba Max Pro Question
Old 01-21-2014, 09:02 PM   #1
Default Mamba Max Pro Question
can some please tell the size of the bullet connectors on wires of the MMP going to the motor the A,B,C wires.
does the size of the bullets connectors determine the gauge of wire you can use, I want to use 12 gauge wire,
but not sure what size of connectors is needed and if they match the esc,
I do not want to cut the esc wires any shorter, if I can help it, and where can I order gold plated solder on connects to make disconnect leads from the esc to the motor.
thank you
kgb424 is offline   Reply With Quote
Old 01-21-2014, 09:07 PM   #2
Default Re: Mamba Max Pro Question
4mm come on the MMP from the factory, you can change them over to the 5.5 castle bullets for 12guage and thicker wire.
4mm bullets are rated to 13guage no thicker.
Although I would try and just get the wire in there. It's possible.
Links are only examples I would check around for your best prices.
Castle Creations 4mm High Current Bullet Connector Set [CSE095-0007-00] | Electric Accessories - A Main Hobbies
Castle Creations 5.5mm High Current Bullet Connector Set [CSE095-0008-00] | Electric Accessories - A Main Hobbies
BuhBoombuh is offline   Reply With Quote
Old 01-21-2014, 10:39 PM   #3
thank you I bought the Castle 4mm bullet connector sets, comes with three males and three female connectors and I bought a shrink tubing assortment and some red, white, black, 13 AWG wire, cause I'm not cutting them esc wires, I'm going to make disconnect leads from esc to motor and wanted use the same gauge as the factory.
Old 01-21-2014, 10:42 PM   #4
Yep just use 13 guage like whats on the esc and your good to go.
Mamba Max Pro Question - Similar Threads
Help please Mamba max pro question Quartermaster Electronics 3 09-30-2013 11:39 PM
mamba max pro question Dr.Newb Electronics 12 07-13-2013 11:00 AM
mamba max pro question Boids Electronics 13 04-30-2010 07:48 AM
Mamba Max Pro question wrightcs77 Electronics 4 01-23-2010 10:00 AM
