Thread: Iron shards/dust on motor can
Old 02-02-2014, 11:30 AM   #1
supermoturd's Avatar
Default Iron shards/dust on motor can
After putting about 8 packs through my Brushed Integy 55T, I noticed what appear to be either iron dust/shards or perhaps magnet shards stuck to the can. Is this normal? If not, what is going wrong? The motor is mounted to an RC4WD R2D trans and sits right next to the dig assembly. Could these shards be from wear and tear in the dig assembly?
Edit: I should add that I don't run my rig in dirt, mud, or water. It is for pure crawling only.
supermoturd is offline   Reply With Quote
Old 02-02-2014, 11:43 AM   #2
In the band for now.
Default Re: Iron shards/dust on motor can
its brush dust
lemonhead is offline   Reply With Quote
Old 02-02-2014, 12:12 PM   #3
Motors are magnetic, they will pick up anything and everything that has iron in it... Even if you can't see it.
JesterSpec is offline   Reply With Quote
Old 02-02-2014, 01:52 PM   #4
I know that. What I'm worried about is the source.
Old 02-02-2014, 02:04 PM   #5
I had an r2 and noticed the same thing. It was shards from the r2 stripping. Replaced the gears then the same thing happened again
1375 is offline   Reply With Quote
Old 02-02-2014, 03:19 PM   #6
That is what I was afraid of. I wonder if a different grease would help.
Old 02-02-2014, 11:31 PM   #7
I'm with lemonhead.. brush and comm dust. If its around the end bell area of the motor? I don't run any dig and it sounds the same from all my motors, brushed motors..
winnerone23 is offline   Reply With Quote
Old 02-03-2014, 05:20 AM   #8
Around here, if you run in the sand washes, the motor will pick up every shard of iron ore in the sand. It will fill a motor in some places.
Just a thought
Erin is offline   Reply With Quote
Old 02-03-2014, 11:42 AM   #9
I doubt its brush or comm dust.....very little if anything in a brush is magnetic....copper in the comm isn't magnetic either
You either are picking up rocks, sand, etc that contains iron, which is pretty common or something is grinding producing metal shards....which happens as well.
Later EddieO
EddieO is offline   Reply With Quote
Old 02-03-2014, 02:38 PM   #10
MODERATOR™
EeePee's Avatar
I stopped reading when you said,
Cause it's probably from that. Gears were too soft in those things and the dig parts wore out quickly, also.
EeePee is offline   Reply With Quote
Tags
filings, metal dust, motor, shards
Iron shards/dust on motor can - Similar Threads
Another one bites the dust! 8th motor and counting..HELP!!!! hiluxscaler Electronics 18 02-19-2012 10:20 AM
From Dust Duuuuuuuude Chit Chat 12 08-07-2011 08:30 PM
collecting dust backfold HPI Wheely King 4 11-14-2008 07:11 AM
Locker = Dust. EHeye HPI Wheely King 13 04-19-2008 10:40 AM
