Thread: Need help finding Hydraulics
Old 02-04-2014, 01:12 PM   #1
Default Need help finding Hydraulics
I want to make a 1/10 or 1/6th wrecker Like the one i drive from work.
Any ways I want to have a boom Raise up and down and extend. Thats 3 rams there and a wheel lift that goes up, down, in, out, left, and right. Thats 3 more
So i need 6 total. I could do it with 4 but it wouldnt be exactly right. But im willing to comprimise.
I want hydraulics if possible maybe a kit.
It could be something that looks like hydraulics but functions the same. and ideas or website where i can buy kits and parts.
jh1985 is offline   Reply With Quote
Old 02-04-2014, 02:22 PM   #2
Default Re: Need help finding Hydraulics
Here u go...GardenTrucking.com - Precision Model Distributors
Johnnysplits is offline   Reply With Quote
Old 02-04-2014, 03:17 PM   #3
Originally Posted by Johnnysplits View Post
Thanks. It might be cheeper to canabeliz a rc construction
And body know any thing about screw drives?
Old 02-04-2014, 07:49 PM   #4
Yeah, looking through that site would give anyone sticker shock.
Old 02-05-2014, 03:02 PM   #5
Well I did research all day. I found a way to do it with air retract cylinders with a hydraulic conversion from hobby king. But i thats still 250 to 300.
I had a great idea playing with my rc4wd winch. I can use extra winch motors and attach a long bolt to it and make my own screw type lifts.
It wont cost much. Then i will make fake ones for looks or wrap the winch ones i make.
Old 02-06-2014, 01:36 PM   #6
I think this project would be much easier and cheaper if you engineered it using servos. You could control them with a multi channel radio. You wouldn't have to use 1/10 scale servos either.
67mustang is offline   Reply With Quote
Old 02-06-2014, 03:19 PM   #7
Air retracts won't hold much as far as positioning goes its either in or out with a lock feature, and their not very controllable as far as speed either. This subject has been touched on multiple times on a few forums. If your not going for actual operation use as much as looks these could work.
Check out Scale 4x4 R/C - Home or www.rcttuckandconstruction.com for tons of info on hydro and screw drives.
It's not cheap by any means but there's a few company's that have conversion kits that use hydraulic rams w coolant instead of hydraulic fluid and their cheaper but again not as reliable. --- mangon rc does a few kits for construction but could be easily converted for your build.
There's also firgelli actuators which are electric rams that can run direct off a rx like a servo these have been used multiple times with great results and I have used them on a few builds as well. I'm actually gathering parts for a build now and will have 8 of these rams being used throughout it.
--Dan
sickcivic95 is offline   Reply With Quote
Tags
construction, rollback, tow truck, wrecker
Need help finding Hydraulics - Similar Threads
hydraulics spyderwebbcustoms General Crawlers 4 07-21-2010 04:28 PM
could anyone help with hydraulics and servos? jms222 Non Crawler RC's 0 04-21-2009 12:00 AM
Hydraulics craigrobbo Electronics 18 08-23-2008 12:42 PM
Scale hydraulics???? Badpony19 General Scale Talk 25 07-20-2006 08:38 AM
