03-07-2014, 04:20 PM | #1 |
Rock Stacker Join Date: Jan 2007 Location: Carson City
| Wire Size ???
What would be the smallest gauge wire to use safely when wiring the motor to the ESC?? And for wiring the battery (2s & 3s) to the ESC ??
03-07-2014, 07:00 PM | #2 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
| Re: Wire Size ???
What components do you plan on using? What application are you using them for? Crawling, scale, ultra 4, TTC, racing? See a lot depends on what your using it for. Example you can get away with 18-20ga to the esc with a crawler but would not work so good in a racing application. The more info you can give the easier it is for someone to help you. |
03-08-2014, 04:25 AM | #3 |
| Re: Wire Size ???
I'll be wiring up a ROC412 to a RS Gen2, was thinking of using 16awg for this. I will be running 2s & 3s for batterries, will 14awg be enough or stick with the 12awg will be trail running, crawling, G6 kind of running. |
03-08-2014, 09:03 AM | #4 | |
| Re: Wire Size ??? Quote:
I have a ROC412 in my SCX10 with a MMP and I am using 13ga. silicon insulated wire. It will get up around 110 degrees after running a 5300 mah pack. Here is a link to where I am buying the 13 ga wire. 13 Gauge They offer a 3 color package that gives enough to do 1 or 2 brushless setups. | |
Wire Size ??? - Similar Threads | ||||
Wire gauge size? | '65belair | Electronics | 5 | 01-25-2013 10:44 AM |
Wire Size? | Tortuga275 | Electronics | 1 | 03-03-2011 05:53 PM |
Wire size. | Airick | EnRoute Berg | 3 | 06-17-2009 10:00 PM |
What Size Wire | Harvo | Newbie General | 11 | 03-15-2009 10:41 PM |
What wire size | BigKRI | Electronics | 6 | 03-01-2008 01:03 PM |
