Thread: Wire Size ???
Old 03-07-2014, 04:20 PM   #1
Default Wire Size ???
What would be the smallest gauge wire to use safely when wiring the motor to the ESC?? And for wiring the battery (2s & 3s) to the ESC ??
Baddawg775 is offline   Reply With Quote
Old 03-07-2014, 07:00 PM   #2
Default Re: Wire Size ???
What components do you plan on using?
What application are you using them for? Crawling, scale, ultra 4, TTC, racing?
See a lot depends on what your using it for. Example you can get away with 18-20ga to the esc with a crawler but would not work so good in a racing application. The more info you can give the easier it is for someone to help you.
mammoth is offline   Reply With Quote
Old 03-08-2014, 04:25 AM   #3
I'll be wiring up a ROC412 to a RS Gen2, was thinking of using 16awg for this.
I will be running 2s & 3s for batterries, will 14awg be enough or stick with the 12awg
will be trail running, crawling, G6 kind of running.
Old 03-08-2014, 09:03 AM   #4
The 14 ga. wire is marginal for use with the ROC412 doing trail running. It is going to depend if you are going to punching the throttle a lot, how long of runs you are planning and the quality of the wire you are using. Better quality wire can carry more current than lower cost automotive wire.
I have a ROC412 in my SCX10 with a MMP and I am using 13ga. silicon insulated wire. It will get up around 110 degrees after running a 5300 mah pack.
Here is a link to where I am buying the 13 ga wire.
13 Gauge
They offer a 3 color package that gives enough to do 1 or 2 brushless setups.
k7zpj is offline   Reply With Quote
Wire Size ??? - Similar Threads
Wire gauge size? '65belair Electronics 5 01-25-2013 10:44 AM
Wire Size? Tortuga275 Electronics 1 03-03-2011 05:53 PM
Wire size. Airick EnRoute Berg 3 06-17-2009 10:00 PM
What Size Wire Harvo Newbie General 11 03-15-2009 10:41 PM
What wire size BigKRI Electronics 6 03-01-2008 01:03 PM
