03-29-2014, 03:35 PM | #1 |
Newbie Join Date: Jan 2014 Location: england
| changing connections
Ive just bought a car and the esc and motor have connections ive not seen before and i want to change them to a tamiya plug and banana plugs on the esc and banana plugs on the motor, does anyone know how its done who could tell me how to do it or point me in the right direction please. Cheers |
03-29-2014, 05:27 PM | #2 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: changing connections
You'll have to cut off the connector you have and re-solder them with the connector you want. Take a look at you tube and search" how to solder" if you've never done it before. Wires and connectors need to be clean, fluxed and tinned for it all to come together correctly.
03-29-2014, 05:57 PM | #3 |
Ok thank you. Is it safe to change to tamiya and banana connections from the ones on it as i read somewhere not to do it |
03-29-2014, 06:19 PM | #4 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
are ur connectors small and red with the prongs looking like a t if so those r deans and one of the most common plugs out.
03-30-2014, 04:22 AM | #5 |
| Re: changing connections |
03-30-2014, 06:24 AM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
03-30-2014, 06:36 AM | #7 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
I prefer Deans as almost everyone else here uses them and most batteries are delivered with them. Get the original Ultra Deans, much better than the copies that exsists. For motor connectors I prefer 4 mm bullet. Soldering takes a little bit of training. I've found out the hard way to NOT cheap out on the soldering tin. There's very many differences between them, mix of materials and intended use. I don't know what brands you might have in your country, but I've found Stannol S-321 to work very well for me. Doesn't just float out like water when it melts like some other I've tried. |
03-30-2014, 09:30 AM | #8 |
The good news is that if you buy unassembled Tamiya connectors, those are typically installed with crimpers and don't require soldering. Bad news is, they're made of a thin foil and will deform at the first sight of any significant amp draw. In other words,you absolutely WILL encounter connection problems. Don't know how much experience you have with electrical gremlins, but they're really not as fun as you'd think. Some pretty weird stuff happens sometimes, and that connection will always be suspect. Dean's is the most popular. Everything I have has been changed over to Traxxas connectors. XT-60 connectors are gaining popularity. And there's also EC-3, Sermos PowerPoles, and bullet connectors available too. On the bullets, highly recommend decent solder on models, not the (again) formed foil crimp on models. I'd kinda like to know what you have on there, before you go and get all gung-ho on changing out connectors, though. Always make sure you put the female connectors on the battery, as you wouldn't want a screwdriver or something rolling into, and shorting, your battery while on the bench. Typically, the same goes for the ESC to motor connection, female on the ESC, male on the motor. |
03-30-2014, 01:30 PM | #9 |
03-30-2014, 01:50 PM | #10 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
03-30-2014, 01:53 PM | #11 |
03-30-2014, 01:54 PM | #12 |
Tamiya connectors are not meant for any kind of high amp draw situation. In this hobby Deans are the standard. They are a little tricky to solder, but a great product. I have never used one, but I have read the traxxas connectors are easy to solder, and a good connector in high draw situations. If your not good with a soldering station I would find a hobby store to do it for you. A bad connection will cause way more trouble than the couple $'s you would have to pay someone else to solder for you. |
changing connections - Similar Threads | ||||
switching to losi connections | Middside | Electronics | 2 | 05-09-2012 06:08 PM |
lights connections | chiatw73 | G-Made Crawlers | 2 | 01-24-2011 10:26 AM |
Link / Shock Connections???? | aggierc | Newbie General | 1 | 01-08-2010 10:51 AM |
battery connections... | braceysdad | Losi Micro-Rock Crawler | 15 | 12-11-2009 04:48 AM |
Wiring connections? | mhuffman_81 | Electronics | 17 | 07-30-2009 02:32 AM |
