Thread: Castle has sensored ESC but not motor...
Old 05-13-2014, 12:00 AM   #1
Default Castle has sensored ESC but not motor...
okay so what I finally decided to do with my g6
Is go brushless. and I want to go with castle not finding everything that I want in any of the brands. I want to be able to run 4S, be waterproof and sensored. But I can't find one comp that has all the things that I want. Soooo I'm probably going to go with the Mamba max pro for my ESC. And maybe the tekin red line motor cause they are both sensored. Any thoughts???
Is there a better brushless set up???
MEnMYshoes is offline   Reply With Quote
Old 05-13-2014, 01:09 AM   #2
Default Re: Castle has sensored ESC but not motor...
The MMP is not waterproof. And nearly all sensored motor are not waterproof (from the company).
You could home-made waterproof your electronics. So just pick what you want!
SilmarilS is offline   Reply With Quote
Old 05-13-2014, 10:07 AM   #3
You are absolutely correct it's the Mamba Monster 2 that is waterproof not the MMP.
flexychevy is offline   Reply With Quote
Old 05-13-2014, 10:08 AM   #4
how is it that you waterproof yours I read something about I think its called Polly coat. But I heard that gets everything hot.
Old 05-13-2014, 10:11 AM   #5
Mmp
Old 05-13-2014, 11:36 AM   #6
Conformal coating is excellent for waterproofing. I've tried many things. That seems to be the best. You can find it on Amazon perhaps other places.
Epoxy also works too. Something that cures.
robertjpjr is offline   Reply With Quote
Old 05-13-2014, 12:26 PM   #7
I'm curious to know what other people are running in there crawlers. And likes and dislikes about there set up.
Old 05-13-2014, 12:53 PM   #8
The Mamba Max Pro is a good ESC
The Hobbywing 3656SD Motor is a very good, strong motor. Highly recommended by many.
I have not used it personally, but I have many other HobbyWing products and they are top notch!
This setup is good for your 4s requirements. If you waterproof the sensor board on the motor and ESC pcb board you will have the perfect combo!
Also, I have used the Hobbywing Xerun 150 amp ESC sensored up to 6s. They have combo's available that would suit your needs.
check out falconsekido.com
The MMP has more functionality, like being able to do brushed motors if need be, but the Hobbywing ESC can handle higher amp draw motors. The MMP is only rated for about 80 amps (I could be wrong here) but not by much.
Old 05-13-2014, 10:51 PM   #9
Excellent, thank you. I will definitely look into it. I have seen hobbywing ESCs and motors on ebay and RC sites but have never read anything about them.
Castle has sensored ESC but not motor... - Similar Threads
Brushed motor for some speed or waterproof sensored esc/motor. Wehan G-Made Crawlers 13 01-30-2014 07:15 PM
Any Sensored ESC with any BL Motor? jlanders001 Electronics 2 03-29-2013 06:17 AM
Sensored Motor and NON Sensored ESC. Timmahh Electronics 7 12-11-2008 09:21 PM
