06-21-2014, 12:29 PM | #1 |
Pebble Pounder Join Date: Jul 2013 Location: SoCal
| Strange motor/esc issue. Help please.
I put a Turnigy 4250kv 4 pole and 120amp trackstar sensored esc set in my wraith. Runs fine until I need to reverse, then is seems like the motor locks up. After a minute or so it frees up and I can continue as if nothing happened. I have re bound the receiver, and reset and reprogrammed the esc in multiple configurations with no luck. Temp is not an issue, as it will do it at first run to anytime after. Any ideas? Thanks. |
06-21-2014, 01:39 PM | #2 |
Quarry Creeper Join Date: Aug 2012 Location: Anchorage
Have you tried a diff RX/TX to rule them out?
06-21-2014, 01:55 PM | #3 |
| Re: Strange motor/esc issue. Help please. |
06-22-2014, 02:27 PM | #4 |
Anyone??
06-22-2014, 02:33 PM | #5 |
Pebble Pounder Join Date: Aug 2011 Location: seattle
Is reverse set to 100% on the esc? Are you running sensored and if so check your sensor wire. Check for binding in your drive train. How many cells are you running? what exact esc and motor are you running? Sent from my SM-G900T using Tapatalk Last edited by colebz; 06-22-2014 at 02:35 PM. |
06-22-2014, 02:49 PM | #6 |
MMP/3656sd FTW!
06-22-2014, 02:51 PM | #7 |
Rev is 50%. Running 3cell. Will switch to another sensor wire to see. Will check the drivetrain also. Its a turnigy Motor ans esc. |
06-22-2014, 02:52 PM | #8 |
06-22-2014, 04:15 PM | #9 |
Try setting reverse to 100%. my hobbyking esc's stutter and act up when reverse is set to anything under 100%. Not sure why. Sent from my SM-G900T using Tapatalk Last edited by colebz; 06-22-2014 at 04:29 PM. |
Strange motor/esc issue. Help please. - Similar Threads | ||||
strange radio issue | 1375 | Traxxas Crawlers | 2 | 08-12-2013 02:29 PM |
Strange issue, please help. | Beej | Axial Wraith | 12 | 02-03-2012 04:29 PM |
A strange issue. | 92xjlaredo | Axial SCX-10 | 11 | 12-30-2011 06:37 PM |
Very strange motor/axle issue | markturbo | Tamiya Clod Buster | 4 | 10-08-2008 04:54 PM |
Strange Electrical Issue | JeremyH | Electronics | 8 | 07-04-2008 06:45 AM |
