11-26-2006, 10:43 PM | #1 |
Quarry Creeper Join Date: Oct 2006 Location: Simi Valley, CA
| NOvak HV Controller w/ BL crawler can????
I really like my HV4.5 but it's I feel it's to much for the TXT. I also love the HV Controller because you can use a dual batt. setup or single and the 6.0V/3.0amp BEC. I was noticing other ESC's and they are usually 6V/1.5amp's. Do you think I can swap the 4.5 motor for the 18.5 Crawler one? It says it can only handle 4-6 Cells, and I only run 2S2P 7.4V lipo pack at a time. So it should be able to handle it. What do you guys think? |
11-27-2006, 09:50 PM | #2 |
Since no one's responding how about the MambaMax 4600 Package. It's brushless and I've used Mamba's before. I love all the programming features and if you look at the pic, everything is adjustable. Drag brake, Punch Control, Brake Amount, Brake Reverse Type. This should work. You can also adjust the throttle and brake curve. |
11-27-2006, 11:13 PM | #3 |
You could use the crawler can with the HV controller. It would be pretty good. With the mamba system you will need an outrunner to get crawler control and performance.
11-29-2006, 04:29 AM | #4 |
Rock Stacker Join Date: Oct 2006 Location: Honolulu
The Mamba setup will be a bit powerful. You'll be fine with your 2S2P and the crawler motor. The Mamba setup is $187, if the crawler motor is close or more than that I would consider the Mamba.
11-29-2006, 03:40 PM | #5 |
Ordered the crawler motor and Novak's new Lipo LVC for 2S. I'll let you know how it handles.
