09-22-2014, 02:00 PM | #1 |
Rock Stacker Join Date: May 2010 Location: tx
| MMP and DTX 4450 Sensored issue
New to thses brushless systems. I have a MMP, with a BEC mated to a DTX 4450 Sensored, With the sensor cable pluged in wether in Brushless or Smart Senser mode, the motor will cog really bad under light throttle,under full throttle it will run then stop and will continue to do that. Once I unplug the sensor cable the it runs fine.Also, this is the motor off the transmission no load just bench testing. Does this sound like a bad sensor board? Thank You |
09-22-2014, 06:23 PM | #2 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Re: MMP and DTX 4450 Sensored issue
Switch it to sensored only mode in castle link. Sometimes smart sense doesn't pick it up effectively. Also make sure it's plugged in all the way on both the sensor and motor. Do you have an extra sensor cable you could try? Dna |
09-22-2014, 09:23 PM | #3 |
Pebble Pounder Join Date: Mar 2012 Location: Port Angeles
Make sure the motor is plugged in correctly A=A B=B C=C. When I had that similar issue that's what fixed it for me.
09-23-2014, 01:30 PM | #4 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
| Re: MMP and DTX 4450 Sensored issue |
MMP and DTX 4450 Sensored issue - Similar Threads | ||||
MMP and sensored motors | RcBro | Electronics | 9 | 06-13-2012 12:20 PM |
MMP & Tekin sensored 13.5 issue | hasbeen | Axial Wraith | 10 | 11-01-2011 07:32 PM |
