09-23-2014, 10:59 AM | #1 |
Newbie Join Date: Aug 2014 Location: albuquerque
| Brown out?
Hey everyone, I got my first 5500mah 3s lipo a week or 2 ago and have been loving it. However, When I go wot from a complete stop the truck glitches. It is like a gave it full throttle let off and then right back into it. This all happens with in a about a half a second from full throttle. Does this sound like a brown out? It only does it from a standing start not a roll or any other time. Its not a huge concern cause I just turn my dual rate down 5% and its fine no big deal. just wondering if this is a brown out situation. Truck specs: wraith psc 20t axial motor AE2 esc power wire removed from rx connector castle bec set at 6.0v spectrum s6030 servo 16t/87 pinion spur combo fsgt3c tx/rx nearly stock weight, no wheel weights.. I am just curious to what you guys think it is. Thanks for the suggestions in advance. |
09-23-2014, 11:25 AM | #2 |
| Re: Brown out?
bump your BEC up a half volt or power the radio with the AE2's bec. You could also install a capacitor on your radio RX. The voltage drop on your main pack is disturbing the BECs output for a fraction of a second.
09-23-2014, 11:37 AM | #3 |
| Re: Brown out?
Sorry I forgot that to add That I am running a Novak Glitchbuster power cap off the reciever. Though I do not notice a difference with or with out it. Also The servo only has ratings for 4.8/6v is this going to hurt it. I notice when I am crawling for extended periods of time it gets pretty warm will the higher volatage cause the servo to overheat?
Brown out? - Similar Threads | ||||
Shift servo brown out? | Antisimplistic | Electronics | 2 | 03-17-2013 07:03 PM |
Brown out? | mannysouza | Electronics | 2 | 05-26-2012 12:57 PM |
Big Brown Blew it !! | bbking9 | Axial XR10 | 5 | 11-22-2011 07:39 PM |
Project Boosted Brown | 1BadJeepBruiser | Chit Chat | 17 | 12-24-2010 10:36 PM |
