09-26-2014, 04:15 PM | #1 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| I got a question about 3s batteries
I was looking at buying some 3s batteries, and all I can find are soft packs, I want some 5000mah 3s hard case Lipo's and the only ones, I found are twice the size of the 2s 5000mah, I got now, So do they make 3s batteries that are same size as 2s and are hard cased, I'm not paying over $70.00 for each lipo either. And not sure if want to buy cheap lipo's and have to replace them quickly.
09-26-2014, 04:51 PM | #2 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
| Re: I got a question about 3s batteries
Since going from 2S to 3S with the same capacity will normally enlarge the battery 50% more in size. If you want a same size battery, you must cut on the mAh rating. But you will have a net capacity in Wh pretty similar! |
09-26-2014, 05:16 PM | #3 |
Rock Stacker Join Date: Jan 2014 Location: Belleville, Ontario, Canada
Venom makes a 3300 mah hard case lipo that work really well. I'm in Canada and you will not find too many decent 3 cell lipos for much less than $70.00 I was a die hard Thunderpower guy, but all my TP packs stated to puff. Have not had any of the red cased Venom puff yet. They have a little lower discharge rate but still great packs
09-26-2014, 06:00 PM | #4 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Is it critical for you to use hard case packs?
09-26-2014, 07:20 PM | #5 |
I seen a bunch of 5000mah 3s lipo's , that are small cause they are for helicopters, and they are 30c to 35c discharge rated, just that they are soft packs, I didn't think you wanted to use soft pack batteries in a rock crawler/trial truck. cause I seen two lipo's short out and catch fire one was in a parking lot watching a group of r/c's drifting and one of them ran over something and puncture the battery and it went up in flames, the second I was out crawling at a popular spot and one of the other guys r/c took a nasty roll and drop and it shorted out and it took a while to reach it just as it went up in flames too. So that's why I paid a little extra to get hard cases for all of my 2s Lipo's. I guess if the soft pack lipo was securely mounted, I should be ok with some reasonable priced soft pack 3s lipo's correct ???? cause I seen some Gen Ace 3s lipo's at a good price.
09-26-2014, 08:48 PM | #6 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: I got a question about 3s batteries |
09-27-2014, 01:05 AM | #7 |
I want use a 3s in my Toyota build cause its brushless and I got a winch and lights and want to see how the battery lasts, and how the performance is before I buy a bunch of them to replace the 2s lipo's I'm using now. The $70 batteries were the Venom 5500MAH lipo's and hard packs, I'm not paying that when a 4500MAH to 5000MAH in soft packs will work for a lot less money
09-27-2014, 03:15 AM | #8 |
I've had zero issues with soft packs in my rig. They just have to be secure. Mine has rolled down hills more times then I care to mention. I happen to run two smaller lipo's instead of one big one...two 2600mah 4s. I tried using one hard case 5000mah, but it was huge and heavy. It broke free a couple of times during roll overs, so I'm not using it anymore.
09-27-2014, 10:02 AM | #9 |
Newbie Join Date: Aug 2014 Location: So. Cal.
| Re: I got a question about 3s batteries SPC Racing has a 4300 mah 3s hard case that is the same size as a 2s pack for only $43.95 with your choice deans or traxxas lead. I have 4 of their 5000mah 2s hard case packs and I'm very happy with their quality.
09-28-2014, 07:31 AM | #10 |
Newbie Join Date: Dec 2012 Location: latonia
Keep in mind goin from 2s to 3s specially in crawlers you will get more run time from the 3s cause your not into the throttle as much..ive found a 3300 3s to last as long as a 50002s in my scx10..
09-28-2014, 09:32 AM | #11 |
| Re: I got a question about 3s batteries More volts = more efficiency which gets you more run time. I love having that extra juice to get out of situations.
10-02-2014, 06:54 PM | #12 |
Quarry Creeper Join Date: Aug 2014 Location: San Diego
All lipos are created equal. There are 3 lipo manufacturers in China. Hobby people, thunderpower, even gens ace buy these batteries for cheap and slap a label on there. And your paying for there name. I found a 3s 2500 mah soft pack at hobby people on sale for 15.00. Can't go wrong there. And there small. Like heli or plane batteries. |
I got a question about 3s batteries - Similar Threads | ||||
Question about batteries | d_j_stockton | Redcat Crawlers | 21 | 01-04-2013 02:57 PM |
Question about batteries? | pito | Newbie General | 16 | 08-13-2008 06:33 PM |
Question about the hustler batteries | jlnash | Electronics | 3 | 03-28-2007 08:04 AM |
batteries tech question | packnrat | Newbie General | 2 | 01-02-2006 09:32 PM |
