12-03-2012, 03:43 AM | #1 |
Pebble Pounder Join Date: Nov 2012 Location: Australia
| Question about batteries
ill start out by saying that im not the most electronically minded so please forgive the noob type questions. i have read in the paperwork for the car that he stock speed controler is good for a 6 or 7 cell nimh battery, and his has got me thinking. i have no plans to upgrade the speedy, so with this in mind im still running stock motors, with 8 tooth pinions ariving very soon, with a view to upgrading to banebot rs390's when i fry a motor in the future. would i benifit more from running and 8.4v nimh hump pack ors running a 2s lipo and an external voltage alarm?? Cheers David |
12-03-2012, 05:15 AM | #2 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
Lipo will always be the better performer.
12-03-2012, 06:14 AM | #3 |
| Re: Question about batteries
doc, will i see any reduction in clod stall when useing the lipo because of its better power delivery properties?? also what "c" rating should i use?? found these on ebay 7.4V 5000mAh 30C Li-poly LiPo Li-Po RC Battery Pack | eBay what do you think?? |
12-03-2012, 06:20 AM | #4 |
Pebble Pounder Join Date: Feb 2012 Location: Bedford
I ran a 2S lipo, and an 8.4 hump pack in mine at different times. The performance was actually pretty close, but the weight difference was unbelievable. The lipo is tiny compared to a NiMh of the same size. I tossed a 3S in mine, and it ran perfect(with MASSIVE performance gains.), until I flipped it into a creek and wet down the esc. They tell me it shouldn't run a 3S, but it was doing fine until then. My son's is on a stock esc, and 3S, with several packs through it, and running fine too. Your mileage may vary. Your esc may melt the first time you try it. (but it probably won't). Sent from my rooted GNex using Tapatalk 2 |
12-03-2012, 07:04 AM | #5 |
If you are ordering out of China, I would just go with Hobbyking.com and get a good well known battery from a good supplier. that battery you posted is not one i have ever heard of and with Lipo i would not chance an unknown pack. the stock ESC is only rated for 8.4 volt, but i know a lot of guys on here have run 3s for a long time with no issues. My dad recently switched from a 9.6 volt pack to a 2s pack and the performance increase was night and day on the stock the controller. that same rig is right now running a no name Chinese made 4s rated ESC and 3s on the stock motors, it still has clod stall, but it works more as a rear dig now. In other words at low speeds the rear will stall, but it has enough power to over come it when you pull the throttle, works super nice. I am currently running a 30C on my 5000 mah 3s and 25c on my 6000 mah 2s. i think the lower the Mah, the higher the C rating should and the higher the Mah the lower the rating from what have been told . All in all, you should be fine in the 25 to 30 C range, you don;t generally need a done of burst in crawling unless you are comping.
12-03-2012, 04:42 PM | #6 |
Pebble Pounder Join Date: Oct 2012 Location: Reno
I run value hobby Gforce 2s 800mah 30c lipos , $5.50ea And ship out of Illinois .They are great for there compact size. There run time is ok for there small size. I would spend 3 more dollars next time and get 1300s , they are just a touch bigger. Im using the stock esc with no problems. I didn't notice Any power gains switching to 2s lipo over 7.2 nimh. Just more consistent power till it hits the set voltage on alarm. I plan on switching to 3s in the near future. Strictly for the power gains of 11v. I will try 3s with stock esc , although not reccomended ! Many have done it with great results , although some went up in smoke. If it frys , well I'll upgrade the esc. 8.4v nimh may have a lil more juice when fully charged than 7.2 lipo will , but more than Likely the 8.4 nimh will fade where the 7.2 lipo holds consistent till its dead. Lipos can be a pain to deal with at times. Never let them go below there limit , and be careful with charging and storage. Lipos require a lipo charger , regular nicd/nimh charger will not do. Last edited by G's ^; 12-03-2012 at 04:48 PM. |
12-04-2012, 08:49 AM | #7 |
Rock Stacker Join Date: Mar 2012 Location: Colorado Springs
I run 3s lipo on stock speed controller and stock motors with a low voltage alarm, and I will NEVER go back.
12-04-2012, 04:03 PM | #8 |
| Re: Question about batteries |
12-04-2012, 10:17 PM | #9 |
Thanks guys for the advice, cheers David
12-06-2012, 09:42 PM | #10 |
Quarry Creeper Join Date: Oct 2012 Location: Cashmere (central WA)
3s lipos, alarm & charger ordered from Hobbyking today. Will report back after the test |
12-06-2012, 10:02 PM | #11 |
12-15-2012, 06:47 PM | #12 |
Rock Stacker Join Date: Nov 2012 Location: USA Ga.
Forgive the stupid question but Going with lipo's is lighter I thought the weight from the heavier nimh Batts would help with traction or does it not work that way |
12-15-2012, 10:09 PM | #13 | |
| Re: Question about batteries Quote:
What works best for me was dropping weight wherever I could , and going with small 2s Lipo lacks and mounting them on to the front axle. That along with taking out my electronics tray and mounting all electronics with Velcro down low to the skidplate made huge center of gravity / stability gains. Look at most all xr10 / berg / bullys , they drop down in the 4lb range , and all run small lipos on axles where weight is needed and keeps the battery down low as possible. A scaler rig won't care about weight as much , they want really long run times and won't do most of the lines a good comp rig will do. So larger heavier nimh or hard case LIpo stick pack battery's isn't a big issue. Last edited by G's ^; 12-15-2012 at 10:11 PM. | |
12-16-2012, 02:07 AM | #14 |
Thanks for the info G's^ I have allot to learn about crawlers yet |
12-30-2012, 05:46 AM | #15 |
I am thinking of going lipo after reading this. I may have missed it but what is a good c rating? Do I need to use a hard pack or is a regular lipo ok I have ordered a low voltage alarm out of China so it should be here oh next year or so And last but not least to get a 20 to 30 minute run time what mah should I shoot for I am running pretty much stock and I plan on staying with 2s |
12-30-2012, 12:54 PM | #16 |
I'd go Atleast a 30c . I use soft packs , hard packs work too but usually are heavy and bigger in size. Screw ordering from china man , volt alarms Are like 3$ from value hobby , batteries not much more and out of Illinois. My 2s 800mah packs running consistant non stop last from 10-15min depending on the terrain. My 1300 mah packs go I'd say 20-30 may be less depending on terrain and how hard I gotta get in it and how often. I run small packs because the battery is mounted on my front axle , so nothing over 1300mah soft packs will fit on my axle. If your running it in the stock tray you could get a 6000mah and run all day on a battery , if you don't care about weight.
12-30-2012, 01:43 PM | #17 |
Thanks G's ^ Great info I will checkout. Value hobby I will see just how mad the wife will get with my next order. (LOL) Last edited by nolan533; 12-30-2012 at 01:53 PM. |
12-30-2012, 04:26 PM | #18 |
Pebble Pounder Join Date: Mar 2011 Location: columbus
Ya I can vow for value hobby I bought there lipo alarms and some batteries fast shipping and cheap Sent from my iPhone 5 using Tapatalk |
12-30-2012, 06:23 PM | #19 | |
You will be surprised on how affordable there battery's are , and so far no compromise for quality. | |
12-31-2012, 10:14 AM | #20 |
I have bought from value hobby before I just had forgotten about them.
Question about batteries - Similar Threads | ||||
Question about batteries? | pito | Newbie General | 16 | 08-13-2008 06:33 PM |
Question about the hustler batteries | jlnash | Electronics | 3 | 03-28-2007 08:04 AM |
batteries tech question | packnrat | Newbie General | 2 | 01-02-2006 09:32 PM |
Newbie question about charging new batteries | Pineaple | Electronics | 1 | 02-08-2005 11:41 PM |
