10-10-2014, 08:52 AM | #1 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
| Futaba 4px programming
Hi, I just bought the 4px to replace my old normal 4pk. On the old 4pk i had the dig programmed on ps2.. I want to have this back, but the programming style is way different.. I can get the dig programmed under the ps2 button, but then its turned on but i cant turn it off and back to 4wd with the same button. I can program it under a dt switch, but i like to have it under the ps2 button. |
12-26-2014, 11:19 PM | #2 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
| Re: Futaba 4px programming
I like it on the PS2 switch also and finally figured it out but not with the new fancy shmancy programming unfortunately. I am sure there is a way, but we will have to wait for Harley to show us how... LOL I used Program Mix 1 and Program Mix 2 just like you program the 4PK. Only difference was Mix Mode ON, Mode ON in the mix screens and Program Mix 2A when you set DT4 as your rear motor trim. I also set PS5 for rear burn instead of PS1 so it is easy to hit with your thumb. |
Futaba 4px programming - Similar Threads | ||||
New Futaba 4PX | EverettY | General Crawlers | 49 | 09-15-2015 12:01 PM |
Futaba 4PX | 8bassotto | Electronics | 0 | 09-22-2014 12:29 AM |
Futaba 4PX | Johnnysplits | Electronics | 5 | 06-07-2014 05:01 PM |
Futaba 4pks programming Q | Ola | Electronics | 7 | 12-30-2011 09:27 AM |
Programming a futaba 3PM | krawlinCJ | Electronics | 4 | 04-27-2007 10:01 AM |
