11-21-2014, 08:49 AM | #1 |
Newbie Join Date: Sep 2014
| Can you reattach a servomotor gear??
I did my searching both here and on Google but can't find the answer so I'm resorting to asking. I have two servos where the gear on the servo motor have come loose and I'm wondering if anyone have any idea if it's possible to get it to stick again or it the servos are best placed in the "stuff I might need" box? |
11-21-2014, 09:01 AM | #2 |
| Re: Can you reattach a servomotor gear??
Use retaining grade loctite, typically "green" or "purple".
Tags |
gear, loose, problem, servo |
Can you reattach a servomotor gear?? - Similar Threads | ||||
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
AX10 shift kit or shifting from Low gear to High gear? | legobrains | Axial AX-10 Scorpion | 19 | 10-27-2007 12:24 AM |
