01-12-2015, 06:52 PM | #1 |
RCC Addict Join Date: Apr 2009 Location: LA
| Where to buy potentiometer?
I have a hitec mg645 with busted potentiometer from using too long of a servo horn screw.
01-12-2015, 07:40 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: Where to buy potentiometer?
Best bet would be to send it in to hitec.
01-12-2015, 08:58 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Or to find a local that has turned one into a winch. I have 3 around here somewhere..... With good boards still hooked to em.
01-12-2015, 09:50 PM | #4 |
| Re: Where to buy potentiometer? Sadly, not so many locals round here. Any chance you'd like to send me one? The board may also be toast as it overheated when I plugged it in before I knew it was broken. PM me if you're interested.
01-12-2015, 09:55 PM | #5 |
Pm sent.......
01-13-2015, 02:45 AM | #6 | |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
| Re: Where to buy potentiometer? Quote:
I have a spare servo I was going to use for winch but didn't. Are potentiometers from different servos interchangeable? Can I for instance buy cheap servo and use it as potentiometer donor? | |
01-14-2015, 09:59 AM | #7 | |
When you connect it, there is a chance you might get the wiring wrong. Most likely you will get the center wire in the right place but get the two outer wires in the wrong place. If this happens, the servo will slam all the way in one direction so be ready to unplug it in a hurry when you test it. Just put the wires back on on the opposite ends and you should be good. I have a bunch of servo circuits complete with pots - contact me if you need one. | |
01-15-2015, 12:43 AM | #8 |
heyok, thank you for reply. I will try replacing potentiometer and post results here. BTW your winch controller is awesome, like it very much. |
01-21-2015, 03:02 AM | #9 |
Potentiometer form winch servo did not fit. There are reduction gears with output shaft. Some pics in my SCX10 thread. Will wait for suitable donor to try it again. |
01-21-2015, 01:04 PM | #10 |
| Re: Where to buy potentiometer? Although the value of the potentiometer is not important. You need to consider physical size and shaft style....also, the amount of range the pot has. (most pots are 270* in range. But I've seen 90*, 63*, 180* pots. Or you can get into multi-turn and continuous rotation. )
Where to buy potentiometer? - Similar Threads | ||||
esc harwiring to a potentiometer and toggle? | cooterwrenchen | Electronics | 1 | 06-06-2013 09:16 AM |
Radio Potentiometer Wiring | SMR 510RR | Electronics | 35 | 10-28-2010 06:16 PM |
need potentiometer tech to fix welder | JamisonWorkshop | Electronics | 2 | 10-17-2006 07:48 AM |
self centering potentiometer | powertuned | Electronics | 0 | 05-13-2005 03:37 PM |
