Thread: mt 4 raido
Old 05-29-2015, 11:59 PM   #21
BDR
Default Re: mt 4 raido
As above, find one in ya budget and buy it.....is the backlight worth the extra, to me it is
I have had a couple of these things, and the backlight is just makes the whole thing, small thing, but when needed it loss is noticed
BDR is offline   Reply With Quote
Old 05-30-2015, 09:35 AM   #22
order one at the shop for 240
vito is offline   Reply With Quote
Old 05-30-2015, 10:00 AM   #23
Airtronics MT-4 SSR 2.4 GHz Radio System w/RX-461 FH4T 4-Channel Receiver [AIR90481] | Electronics - AMain.com - AMain.com
Old 05-30-2015, 11:21 AM   #24
Come and take them!®
Hunter711's Avatar
I personally have three MT4's. All model slots full w/vehicles. Several receivers available. I like this Rx for waterproof ability. With a little trimming, it fits Yeti receiver compartment.
Airtronics RX-371W Waterproof 3-Channel 2.4GHz FHSS-2 Receiver [AIR92621] | Electronics - AMain.com - AMain.com
For nitro the temp censor unit function is perfect:
Airtronics RX-461 2.4GHz Telemetry Receiver (MT-4) [AIR92010] | Electronics - AMain.com - AMain.com
I have Futuba 4PK for crawlers, but all round I like MT4 the most.
Hunter711 is offline   Reply With Quote
Old 05-30-2015, 03:12 PM   #25
I got my MT4S anniversary edition for $379. It came with 2 receivers and a limited edition carry case. It has a piano black finish with a red and black aluminum wheel. Feels great running my Yeti.
CamaroTom is offline   Reply With Quote
Old 08-27-2015, 12:07 AM   #26
Ok, Airtronics gurus out there. I have an Airtronics MT-4 and have every RC car from a Slash to a Mugen MBX7R ebuggy. I just ordered the Trail Finder 2 and want to use the 2 speed tranny with the lever or a button, I think, and the winch with something else. What do you guys think. I have no clue yet on how to even program the radio to do this operation. So, i'm asking for help (Not Directions.......I can get lost all by myself, thank you.) Anyway, I have a 4 channel receiver that came with the MT-4 and plan on using it. Please advise. Thanks
HollywoodRC is offline   Reply With Quote
Old 08-27-2015, 03:01 AM   #27
Help, but not direction....
Yes, the 2 speed works great on the lever.
winnerone23 is offline   Reply With Quote
Old 08-27-2015, 06:40 AM   #28
I like to use a button for anything that is 2 position, like a shift servo. The 2 point movement of using a button is consistent and easy. My favorite use of the lever is for a winch with a small ESC to control the it. The lever allows proportional speed control of the line going in and out which you can't do with most other radios.
svt923 is offline   Reply With Quote
Old 08-27-2015, 02:41 PM   #29
That's interesting. How do you set up the lever to do speed and direction. I thought it had two points on and off up or down. Can you position it in the middle for a neutral? I do like the button idea for the 2 speed shift.
Old 08-27-2015, 05:13 PM   #30
I forget the setting in the radio the 3rd or 4th channel has to be set to but there should be a point in the middle of the lever travel that you can feel it stop. That point is 0. As you move the lever in either direction, it either increases or decreases in steps to 100. You can calibrate a speed controller to the lever just like the throttle trigger.
Old 08-28-2015, 12:51 AM   #31
Thanks for all the info. I am doing all the research before my Trails Finder 2 shows up in September.
mt 4 raido - Similar Threads
Raido??? Red_13 Venom Creeper 2 01-28-2012 07:09 PM
Raido ? Ben06 General Scale Talk 0 09-26-2010 07:12 PM
raido glitch mini max Newbie General 4 05-29-2009 08:57 AM
raido question dmgriff266 Newbie General 3 11-04-2008 06:34 PM
which raido? ElkySS Electronics 5 05-22-2008 06:14 AM
