06-09-2015, 09:55 AM | #1 |
| Position a servo with a toggle switch
Recently a customer wanted a way to move a servo on his rig to two different positions. I didn't ask why (or I forget ), but I expect a gizmo like this would have a few uses. Lets say you want to run a two speed transmission on your truck but you don't have a spare channel on your radio. This part lets you position a servo just by flipping a toggle switch. Two trim pots lets you set exactly where the servo will park in both of the switch positions. I don't know how many of you would need something like this, so I wanted to post up a prototype to get some of your feedback. You can plug this into a spare port on your receiver or feed it power from a Y connector on any of your servo plugs. The controller isn't too fussy about how much voltage you run through it, so it would work fine for a high voltage servo if that is what you want to do. Watch it here: https://youtu.be/QxLUY6yRsxE Last edited by heyok; 06-09-2015 at 10:38 AM. Reason: Added link to youtube video |
06-09-2015, 05:18 PM | #2 |
Rock Stacker Join Date: Jan 2010 Location: Tijeras
| Re: Position a servo with a toggle switch
Thats cool Al, I would use something like that for using on a custom trailer build where the ramps would be raised and lowered by that switch. Okay question could you wire it to where it could have a ON-OFF-ON switch so that it could power like one of your 3 position servo winches?
06-09-2015, 05:26 PM | #3 | |
| Re: Position a servo with a toggle switch Quote:
Yes, I could make it do three positions and it could operate a three position channel servo winch. If you really want to run a winch from a toggle switch though, you can do it and you don't need any electronics. Just wiring. Using one 3 position toggle, you can have Winch In, Stop and Winch Out. Compared to using one of my winch controllers though, you won't have the electric brake when it is in stop mode. It is possible to simulate a brake if you use two toggle switches. Let me know if you guys want to know how to do this and I will show you in another thread. | |
06-10-2015, 09:44 PM | #4 |
Moderator Join Date: Jan 2004 Location: chicago
i could see how this would be neat for non rc stuff, like actuators for hidden panels in autos to hide rare birds or something. ;)
06-10-2015, 09:48 PM | #5 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
If I had a 2 speed transmission in my wraith I could use this to replace the faux shifter that gets screwed into the interior body work...
06-11-2015, 06:00 AM | #6 | ||
Does "rare bird" mean something or am I just looking for meaning that isn't there? Quote:
Maybe I should post this up as a regular part for sale. Can I make one for you? | ||
06-12-2015, 11:25 AM | #7 |
no hidden meaning. ;) i saw a news story once on smugglers of all types. i was amazed that there are bird smugglers. they showed a car that had birds stuffed in tubes everywhere. |
06-13-2015, 11:23 AM | #8 | |
Quarry Creeper Join Date: Nov 2010 Location: Canada
06-13-2015, 03:11 PM | #9 |
| Re: Position a servo with a toggle switch |
06-14-2015, 10:15 AM | #10 |
Thanks Heyok! Seems fairly straightforward. Also looks like I could add a second winch and On/Off switch and be able to run both from one DPDT switch allowing either one to run or actually have both spool in or out at the same time. Now I can't wait to get going on the winches. You da man Heyok!
06-15-2015, 06:08 PM | #11 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
Can you PM me a price for one of these? Would be great for my 2 speed transmission in my wraith. Wes |
06-16-2015, 05:55 AM | #12 |
06-16-2015, 12:53 PM | #13 |
Added this as a new product in the vendor section: Toggle Switch Servo Positioner |
06-17-2015, 09:32 AM | #14 |
I've done a bit more work to this and now you can have three positions using a toggle switch. It will use one of those three position toggle switches. There will still be two pots on the controller. When the switch is in the center position, the servo will be centered. Swing the switch left or right and the left or right pot sets those servo positions. |
06-17-2015, 01:13 PM | #15 |
Could I just dip this thing in silicone conformal coating for waterproofing purposes? Not planning on getting into deep water but want to prepare for the worst just in case. Wes |
06-17-2015, 01:51 PM | #16 | |
Conformal coating would probably work fine too. My concern is that it would run inside the crack around the rotating part of the pot and make it so you couldn't adjust it anymore. | |
06-17-2015, 02:18 PM | #17 | |
So just dip the whole thing in a bowl of the plastidip that typically comes in a paint can type container? Wes | |
06-18-2015, 10:02 AM | #18 |
Most of it is already covered in plastidip. Just need to cover up the openings for the pots on yours. Usually I just use an old chopstick to apply it. Dip your stick it in the goo, then spread it around the hole. I didn't really mean for that to sound dirty. |
Position a servo with a toggle switch - Similar Threads | ||||
Servo Toggle Switch | heyok | Vendors Electronics | 19 | 03-18-2015 05:20 AM |
Can I get my Futaba 3PM 3rd channel to work a servo to toggle my light switch? | jedi | Newbie General | 2 | 08-10-2009 07:12 AM |
Toggle switch on a servo??? | Biscuit | Electronics | 1 | 04-11-2009 01:16 AM |
Can a three position toggle be installed in a m8? | rockdevil | Electronics | 3 | 08-11-2008 09:29 PM |
