Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Electronics
Thread: Toggle Switch Servo Positioner
Old 06-16-2015, 12:42 PM   #1
Default Toggle Switch Servo Positioner
June 17, 2017: Made another version of this part. Now you can get a three position version. More info below.
This part lets you position a servo just by flipping a toggle switch.
Two trim pots lets you set exactly where the servo will park in both of the switch positions.
No problem running a high voltage servo as this controller will take 10 volts.
This part is now available for two or three servo positions.
The three position version comes with a three position toggle switch. The center position puts the servo in the center of its rotation - therefore there is no pot for the center position.
Update March 15, 2017 Now available with a speed control:
I've had a few customers using this part for building their cosplay needs. Check out these two links:
https://www.youtube.com/watch?v=xbfYJcIl2yw
https://www.facebook.com/brian.w.wil...8815326673339/
Two position version is Part Number TGSP2
$30
Two position with speed control is Part Number TGSP2S
$37
Three position version is Part Number TGSP3
$35
Last edited by heyok; 07-13-2017 at 11:13 AM. Reason: Photobucket support over, switching to imgur
heyok is offline   Reply With Quote
Old 01-03-2016, 02:22 PM   #2
Default Re: Toggle Switch Servo Positioner
Just realized that I didn't post up the video I made for this part. Here it is:
https://www.youtube.com/watch?v=QxLUY6yRsxE
Old 06-08-2016, 10:51 AM   #3
Since I'm still on rtr tx do you have anything that I could use to set the endpoint on my steering servos? I just don't want to switch all my RCs over to one radio, since I've been getting my little bothers to come and play I need separate transmitters, plus they're kinda hard on my toys.
Alexander_0_1 is offline   Reply With Quote
Old 06-08-2016, 10:58 AM   #4
I'll send you a PM and we can figure this out.
Toggle Switch Servo Positioner - Similar Threads
Position a servo with a toggle switch heyok Electronics 17 06-18-2015 10:02 AM
Servo Toggle Switch heyok Vendors Electronics 19 03-18-2015 05:20 AM
Servo positioner heyok Electronics 0 10-17-2012 03:50 PM
Can I get my Futaba 3PM 3rd channel to work a servo to toggle my light switch? jedi Newbie General 2 08-10-2009 07:12 AM
Toggle switch on a servo??? Biscuit Electronics 1 04-11-2009 01:16 AM
You may edit your posts
