06-25-2015, 10:24 PM | #1 |
Rock Stacker Join Date: Mar 2015 Location: Mahopac
| Vanquish LED light bar - 6S
On my yeti XL, I just installed the 6" VP LED light bar. I know it can't support 6s, but it will work on 3s. I have a 20 amp CC BEC already which I use to power the fan and servo. I just tapped off that BEC output for these lights. But...the lights aren't working. The voltage is set at 6v. I can bump it up to 7.4 and the servo 7950TH can handle it. Just wondering if there is a minimum voltage reauired. I have power to the lights. And the lights work when connected direct to a battery. Thoughts? |
06-25-2015, 10:53 PM | #2 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Re: Vanquish LED light bar - 6S
Not sure about minimum volts, but it sounds like you need another bec, I had the same scenario when I put my BMRC if/rs wraith on 4s. I never did hook them up to a bec that was pushing 6v though, I just had a buddy lone me a CC bec pro that he wasn't using, and asked him to set it to 12v for my test. You just reminded me I need to find my own bec that can output 12v. |
06-26-2015, 07:46 AM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Vanquish LED light bar - 6S |
06-26-2015, 09:00 AM | #4 |
Jeez! I have two of those, and I never even thought about that......
06-26-2015, 09:17 AM | #5 |
I don't know if there is a minimum voltage required but anything less than 11V just does not create any appreciable light output. When I was setting up the light bar on my truck, less than straight 3S voltage was useless anywhere other than a completely dark room.
06-26-2015, 10:49 AM | #6 |
I guess I'll have to get a second BEC then just to run the lights. Ugh! Thanks for the info! 6" fits perfect for the YXL. Last edited by Bmelch; 06-26-2015 at 10:52 AM. |
06-26-2015, 11:37 AM | #7 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
Why not just get a small 800mah jst connector 3s? Then put a 5$ lipo cutoff on it? That's how I run them.
06-28-2015, 09:48 AM | #8 |
06-28-2015, 09:49 AM | #9 |
Like 2 hours. You can pick up the batteries on hk or somewhere like that for a few $ each. They are cheap.
Vanquish LED light bar - 6S - Similar Threads | ||||
Vanquish Rigid Industries 5’ LED Light Bar. Are they all like this?! | PSW | Axial Wraith | 67 | 06-19-2016 08:04 AM |
Larry 8 LED Pocket Work Light as cheap scale light bar | spoo76 | General Scale Talk | 8 | 12-15-2014 06:38 AM |
