12-02-2015, 02:31 PM | #1 |
Newbie Join Date: Jan 2014 Location: Darwin
| 4PLS channel 2 problems and Holmes Esc programming
Hi y'all. I have just finished putting together berg v3 and have set up my 4PLS for dual esc. The problem I am having is that my channel 2 has no reverse, in or out of dual esc mode. Any suggestions regarding how to fix this. Also, i am using two smashed Holmes mini BRs Esc, I have purchased a Castle Link for programming, not quite sure what to do here either, but the question is if I have cut the red wire on the 'control feed' can I still program the esc? I m very new to all this so any help would be appreciated. Thanks D. |
12-03-2015, 03:40 PM | #2 |
Newbie Join Date: Jun 2015 Location: Right their !!!!
| Re: 4PLS channel 2 problems and Holmes Esc programming
The red wire must be hooked up to connect it to castle link.
12-03-2015, 08:42 PM | #3 |
Thanks have set esc's to default but I can't get channel 2 to reverse. Could it be the radio. When I push the trigger forward then LCD display indicator for that channel shows nothing, unlike when I pull on it.
12-03-2015, 09:39 PM | #4 |
Quarry Creeper Join Date: Sep 2005 Location: Chico, CA
I had the same problem on my 4PK, see if switching brake-mode to inactive helps.
12-05-2015, 04:30 AM | #5 |
I ended up getting reverse, changed the Throttle ALT setting for BRK to 100. I really don't understand why it works now, but it works.
4PLS channel 2 problems and Holmes Esc programming - Similar Threads | ||||
Holmes Hobbies ESC setup / programming | lothargores | Electronics | 3 | 06-15-2014 08:07 PM |
The new Futaba 4PLS dual esc programming issues | morpheus_tn | Electronics | 3 | 03-06-2014 09:28 PM |
traxxas xl5 esc programming problems | rccherocon | Electronics | 3 | 11-02-2010 11:40 PM |
FXR programming problems | 4x4incole | Electronics | 1 | 08-19-2009 10:59 PM |
