05-12-2016, 03:41 PM | #1 |
| AE2 and 3s Lipo
Can I safely run 3s Lipo with the Axial AE2 esc? I read through the forms and keep seeing that people are running a BEC? What exactly does this do and do I need to have one to run 3s with the AE2? (sorry, bit of a nube with the electronics). Any info is appreciated! Thanks!
05-12-2016, 04:21 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: AE2 and 3s Lipo
The internal BEC of the AE-2 isn't strong enough on 3S to handle a decent servo. If an external BEC is used to power the servo, the AE-2 will work fine on 3S.
05-12-2016, 05:04 PM | #3 |
| Re: AE2 and 3s Lipo
I hooked up 3s using my AE2 but not without an external BEC. And using a external BEC will be necessary. better then just using an external BEC is to utilize the Holmes Hobbies RX by-pass "Y" harness. Then the ESC's internal BEC supplies voltage to the RX. and the external BEC supplies the required voltage that the servo might need to operate at it's peak. If not using the RX by-pass "Y" then the ESC's red+ wire leading into the RX will need be removed. And the external BEC will supply voltage to both the RX and servo. If using the HH's RX by-pass "Y" then the ESC's red+ wire leading to the RX needs remain as the ESC's internal BEC will supply the RX and the external BEC will supply voltage directly to the servo. The HH's RX by-pass "Y" harness is plug and play and costs only $ 6.00 (well worth the added cost) HH's RX by-pass "Y" harness... RX Bypass Adapter - Wiring & Wiring Accessories - Electronics & Wiring CC BEC... BECs & Voltage Regulators - Electronics & Wiring IMO... the independent voltage supply to the RX and Servo is the most efficient/reliable method. If not using the HH RX by-pass... then be sure the RX can handle the servo's required voltage demands. And adjust the BEC's voltage accordingly. Some servo's require more voltage then what should be run thru the RX. Generally most RX's will only handle 4.8 - 6. volts run thru. Here's picture entailing how simple the RX by-pass installs. granted not the AE2... but the same RX by-pass works for either and most other ESC's. Last edited by TacoCrawler; 05-12-2016 at 05:09 PM. |
05-13-2016, 04:09 AM | #4 |
| Re: AE2 and 3s Lipo
Thanks guys. I did some reading up on everything last night. I've always been good with mechanicals, not so much with the electrics:O @TacoCrawler - thanks for the pictures and in depth explanation. This helped a lot! Looks like with the HH Y connector it's a simple "plug and play" deal. Having said that, now that I've gone to his web site, I'm seriously considering doing a motor / esc combo from him! I've read a ton of positive reviews on his stuff here!
05-13-2016, 09:37 AM | #5 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: AE2 and 3s Lipo
The heyok no brainier bec is the easiest plug and play bec you can buy. No bypass harness, no castle link to deal with, no pulling or cutting out any wires, and it's easily adjustable or he can preset it for you when you order it.
05-13-2016, 03:59 PM | #6 |
| Re: AE2 and 3s Lipo
Awesome - I will look in to the heyok as well. Thanks for all the info guys!
05-15-2016, 04:00 AM | #7 |
| Re: AE2 and 3s Lipo
Heyok offers well constructed, reliable, quality electronics. I like my heyok wireless winch controller alot, performs well, is durable and has proven to be reliable. Simple purchase/easy install... voltage is adjusted to your preference when making purchase - no charge. Will probably require re-shrink wrapping if ya make your own manual adjustments. Still, when utilizing the Castle and Homes Hobbies products combined. Both distributor's utilize Casle compatible products. So if running these components and making programing adjustments it would be near a priority to own the CC USB/link as well. So I guess what I'm sayin is... If ya have the USB link already for CC/HH component programming Then might as well use the link to program a CCBEC ?! So it basically comes down to do ya want a manual adj. BEC or do ya want a pc programmable BEC !? The heyok NB'r is manually adjusted... while the CCBEC is PC programed. Regardless !! I would double check any BEC's output voltage manually using a voltmeter to be sure the voltage is set as was intended. |
AE2 and 3s Lipo - Similar Threads | ||||
13.5T too much for AE2? | J5races | Electronics | 8 | 03-23-2014 08:44 PM |
AE2 LiPo cutoff? | Timo Creemers | Electronics | 2 | 02-11-2014 02:22 PM |
AE2 ESC to Receiver wire/cable polarity & AE2 ESC switch position. | Tread Well | Newbie General | 7 | 06-18-2013 02:14 PM |
ae2 | RCTRUX | Electronics | 4 | 04-06-2011 05:33 PM |
