07-26-2016, 04:28 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
| HiTec 7980 in a Bomber?
Anyone tried running the HiTec 7980 in a bomber? I've got a DWanger on the way, and have only been getting about a month or 2 out of my 7950's before they start exhibiting alot of servo horn wobble followed by non centering resulting from the center support gears mushing out causing alot of run out at the horn. I'm not really sure what to do about it. I think the main issue might be my steering tie-rod occassionally gets forced up into the bottom of the servo horn stressing the gears.....and eventually and understandably so the gears just lose their tight mesh which then leads to centering issues as well. I've got my truck totally bombproofed except for my servo. I just can't keep these 7950's alive for more than a few months. Any thoughts tips tricks of ideas? I'm on my third 7950, and I absolutely LOVE them I just must be too hard on my truck, although the servo seems to be the last weak link in my entire truck. |
07-26-2016, 04:36 PM | #2 |
| Re: HiTec 7980 in a Bomber?
When everything is bomb proof except 1 item keeps failing you either need to reevaluate your choice in brand of replacement parts or your driving style needs some adjustments. I don't see the 7980 having any result different than the 7950. Try a bluebird b50 or even an sg series savox and you'll likely have a different result. My 1283sg savox gets its ass kicked on my bouncer running xl's and it's still tight as could be. |
07-26-2016, 05:05 PM | #3 |
| Re: HiTec 7980 in a Bomber? 420oz-in v3 ProModeler 420oz V2 servo, a real beast - almost totally silent, overbuilt and over-engineered, read the details in their site - $79.99 SHV500 Servo Alternatively the new SHV500 Holmes Hobbies - will run directly off your 3S LiPo w/out a BEC. $119.99 and are also very silent, 450oz torque. Allows for cleaner wiring! |
07-26-2016, 08:12 PM | #4 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
I had a 7955 and 7950 with similar bad luck. Now I run a Promodeler and a HV500. I love them both and they've been WAY more reliable than the Hitecs. I managed to yank one of the servo wires out of my HV500 so I swapped out for the 7950 while I worked on it. After running the silent, brushless motor servos, the 7950 about drove me crazy with it's buzzing and centering fits. I managed to fix the HH servo but part of me wanted it to stay broke so I could justify getting a SHV500. If there's one thing I know for sure - I'll never buy another coreless servo, it's brushless for me from now on. |
07-26-2016, 08:24 PM | #5 |
Thanks for all the great replies, I'm suprised to see other suggestions than the 7950 as I thought it was the holy grail of tough servos but I think I'm ready to try something new. Where are you guys sourcing your ProModelers from? There doesn't seem to be alot of stuff about them online.....
07-26-2016, 08:34 PM | #6 | |
| Re: HiTec 7980 in a Bomber? Quote:
07-26-2016, 09:34 PM | #7 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
What in Satan's unholy name are you doing to your servos? I've been using Hitec HS-7955TG servos for steering duties in all of my vehicles that use standard-size servos for years and my oldest one is still going strong. Coincidentally that one is installed in my Wraith, where it's connected to titanium steering links with no servo-saver, and has survived dozens of trips through the local creek and hundreds of "flying descents" off rocks. I have never heard of someone killing a Hitec HS-7955TG except from old age. If the only problem you have is that you're wearing out the gears, why don't you just replace the gears? You don't have to replace the entire servo, you know. In fact, that's incredibly wasteful. Last edited by fyrstormer; 07-26-2016 at 09:37 PM. |
07-26-2016, 09:50 PM | #8 |
Rock Stacker Join Date: Jul 2015 Location: Fredneck
One suggestion is the Hitec HPP-21 Plus programmer. There are few different models at different price points, but the HPP-21 allows you to program the 7950 (or any programmable Hitec)using a PC or with the adjustment dial on the programmer module. You can adjust the centering deadband and also set an overload protection function that kicks in at a specified percentage of over current. End point adjustment is also easily setup and tested with this programmer. Setting all of these things up correctly may make a difference in the lifetime of your Hitec. I recall all 3 of my 7950s being very noisy and not wanting to find center out of the box. After adjusting the deadband with my programmer, they run quiet and much cooler. I can't attest to your driving or the places you're taking your truck, but I can say this may help you. I know it sucks having to spend a little more money to ultimately save money... You must be pretty hard on your rig if you're going through 7950s that quickly... Good luck! |
07-27-2016, 09:06 PM | #9 | |
To try and answer what I'm doing to do such a thing to my servos; I live extremely close to one of the most amazing RC crawling/hill climbing/trailing spots in the MidWest, and because of that I'm pretty sure my RC has more time on it than most couple that with the terrain it gets run on and being setup with 4s on a HH BL motor, and it all kind of leads to awesomeness, except for my servos. I've blown my rig to pieces multiple times and i've finally gotten it to where now rarely anything breaks except for my servo. My truck on average probably sees 6 to 8 hours of use a week mainly because my baby thinks the greatest thing on the planet is to ride in a baby backpack while we hike about running the RC Yes I agree with you that buying new servos because the gears or in my case gear, goes bad is in fact wasteful. I'm just looking for some tougher options. All three instances, my servo's have exhibited nearly the exact same parts failures; except in one isntance a bearing shim thing also disintegrated. I'm running Currie F9's with SSD c-hubs and knuckles. I haven't looked into if there are any behind the axle steering setups for this or any way to mount the servo behind the axle tube. I prefer the servo on the axle for weight down low and I don't think I see the point of me trying to fab up a panhard kit to run cms as I think that would just add unsprung weight that I don't really want. Anyhow thanks again guys.....think I'm leaning for a ProModeler unless JRH thinks he can make his new Servo run straight off 4s so I can ditch the BEC hehehehehe | |
07-28-2016, 04:00 AM | #10 |
I think in your case I would start looking into 1:8 or even 1:5-scale servos, space permitting. It sounds like that's the only thing that will give you the durability you're looking for. The size of the gear teeth in 1:10-scale servos is limited by the physical size of the servo case and the need to have a precision-fit between the meshing gears.
07-29-2016, 07:04 AM | #11 |
Quarry Creeper Join Date: Nov 2011 Location: In the woods
I did the hitech thing.. now I run HH sv500 in all the crawlers. My 7954SH didn't make it a full day in a bomber with 2.2 growlers. Club buddy had a 7980 and it died in 3 days with a bomber. The 7980's have 1 plastic gear in them, making it a weak point and at 49.99 a gear set for the servo, he ditched the servo.
07-29-2016, 11:43 AM | #12 | |
07-29-2016, 12:26 PM | #13 |
Rock Crawler Join Date: Mar 2016 Location: HB
Silence is golden when your ripping up the wilderness with the HH HV500!! Then my buddy comes along with his highpitchtech and all peace is lost.lol
07-29-2016, 01:32 PM | #14 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
Ive posted this before, I've seen much better luck with the noise on my 7950 by reprogramming the dead band to 4 from 1.
07-29-2016, 01:39 PM | #15 | |
07-29-2016, 04:18 PM | #16 |
| Re: HiTec 7980 in a Bomber? So I'm guessing your motor and drivetrain are also silent? I dunno about you, but I don't hear a thing from my servo over the sound of the steel transmission gears and diff gears, not to mention the sound of the nearby creek.
07-29-2016, 04:19 PM | #17 | |
07-29-2016, 04:33 PM | #18 |
| Re: HiTec 7980 in a Bomber? Yep. I do clean and lube my rigs a lot because we have a lot of sand in the dirt being near the beach. Only noise I really here on my bomber comes from the MMX beeps which are getting turned off
07-29-2016, 11:25 PM | #19 |
Mine are thoroughly greased and oiled too, but the straight-cut gears still make a racket.
07-30-2016, 09:59 AM | #20 |
Moderator Join Date: Jan 2004 Location: chicago
aside from the ricey looks ive been wondering about the bluebird brushless helical gear servo. gears look pretty stout. RC Servos / HV Servos in Taiwan |
HiTec 7980 in a Bomber? - Similar Threads | ||||
HItec 7980 | lurchy | Electronics | 5 | 12-28-2012 06:51 AM |
Hitec 7980 | lurchy | Axial Wraith | 1 | 12-26-2012 08:36 PM |
Hitec 7980 help | crawlinghulls | Electronics | 3 | 12-22-2012 11:44 AM |
