08-10-2016, 12:29 PM | #1 |
Quarry Creeper Join Date: Mar 2016 Location: Ohio
| Battery for lights help
I've got a set of 4 white and 2 orange LEDs for my SCX II, but the JST-XH connectors don't fit in my receiver. So I thought I could get a separate battery for the lights. Which batteries are good enough and have that same connector? Any advice? Thanks Light connectors: http://s1206.photobucket.com/compone...slmy5xkaq.jpeg Last edited by Wes S.; 08-10-2016 at 12:33 PM. Reason: Added pic |
08-10-2016, 12:32 PM | #2 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
| Re: Battery for lights help
Check to see if it has an extended tab if you will on one side....if it does just shave it off and then it should fit. Just don't take off to much. Sent From My Galaxy S6 Edge+ |
08-10-2016, 12:33 PM | #3 |
Wait never mind picture didn't show till I posted lol Sent From My Galaxy S6 Edge+ |
08-10-2016, 12:37 PM | #4 |
Looks like the plugs for the axial simple light Controller. Might be able to find one on ebay....or someone may have one they don't need might try the wanted section of this forum. Sent From My Galaxy S6 Edge+ Last edited by sharkattack99; 08-10-2016 at 12:41 PM. |
08-10-2016, 02:03 PM | #5 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Battery for lights help Quote:
You are not going to find plug and play outside a kit, which is going to come with its own lights. 10 or so dollars on ebay, with brake, reverse, turn signals(I never use), and 4 white lights. They also accept the plugs on the led's you posted. Good luck You could however, run the orange in a series then put resistors on the white to run of a 4.5-5v internal BEC. All that is assuming that you are using the most common 5mm LED's. | |
08-11-2016, 10:39 PM | #6 |
Rock Crawler Join Date: Mar 2016 Location: HB
You need one of the axial light controllers to run those. The orange ones are 3mm led's. What are you trying to do with your lights? They have different ratings on the different strands that you need to be aware of.
Battery for lights help - Similar Threads | ||||
Lights with 9v Battery (simple) | loosenutz | General Scale Talk | 2 | 02-14-2016 01:32 PM |
running lights off a 9v battery? any ideas? | Corey123 | Electronics | 4 | 01-16-2015 03:38 PM |
Battery Charger lights not changing | Blinkfan5150 | Vaterra Twin Hammers | 11 | 02-14-2014 10:26 AM |
ESC lights up with no battery | Quartermaster | Electronics | 2 | 01-23-2012 08:06 AM |
battery life with or without lights on? | theblackmonky | Axial Wraith | 11 | 09-03-2011 04:08 PM |
