10-24-2016, 02:35 PM | #1 |
Newbie Join Date: Oct 2016 Location: New Zealand
| Axial ae-5 question
The ae-5 is rated at 180A, so does that mean that I need a battery with a max amp draw rate of 180A? So like a 3600mAh with a max 50C discharge rating? Thanks |
10-24-2016, 02:59 PM | #2 |
| Re: Axial ae-5 question
it means you can use it for up to a 180A draw.. that may be a max burst draw figure...not sure if it means a sustained 180A...you can use any lesser amount without any issues
10-24-2016, 03:30 PM | #3 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
The short answer is no. As was mentioned, that's MAX capacity, probably the burst number, sustained is likely 90. Highly unlikely that you'll ever get anywhere near that in a crawler/scaler. My rigs tend to average a draw of about 1 Amp (i.e. a 1000mAh battery typically lasts me about .75hr-1hr). That is just the average and it includes all my standing around bs'ing time so it's pretty skewed number, just throwing it out as a base line. Last edited by QuesoDelDiablo; 10-24-2016 at 03:33 PM. |
10-27-2016, 11:43 AM | #4 |
Rock Crawler Join Date: May 2016 Location: SoWIs
The most I was able to see with a Wraith w/ 3S & 45T was 30A holding it down on tall, wet grass. 30C & above is a good idea, but not required for a brushed motor. I've seen boaters use 20C batteries on 4074 brushless motors, which are MUCH bigger. Bigger rarely hurts (beyond weight & price), too small can mean shorter run times, number of charges, or even reduced power. |
Axial ae-5 question - Similar Threads | ||||
Axial AE-5 question | sub-zero123 | Electronics | 7 | 03-31-2016 09:04 AM |
axial AE-2 question | s0uthernpr1de | Electronics | 13 | 09-28-2014 07:26 AM |
Axial ae-2 question | OH91awd | Electronics | 6 | 06-30-2013 08:21 PM |
Axial XR10 and Axial AE-2 esc stoopid noobie question | shelbyzz | Newbie General | 3 | 06-14-2012 06:34 AM |
Axial Question | gary | Newbie General | 36 | 10-12-2009 11:24 AM |
