03-20-2017, 09:15 AM | #161 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
| Re: New Castle Mamba X (sucessor of Mamba Max Pro)
Price point the Mamba X and Mamba Monster X is very similar. I realize it is recommended for a bigger/heavier size rig. Does it deliver more power? Both ESC have aux tuning capability
05-10-2018, 03:01 PM | #162 |
I'm running my Mamba X with a brushed motor. I have the positive motor lead in "A" and the negative in "B". It seems to operate fine, but when I stop it beeps and I have idle beeps disable in the software. Does anybody know why it beeps?
05-10-2018, 03:07 PM | #163 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) Is your data log full? or is that beep disabled too?
05-10-2018, 03:57 PM | #164 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) Quote:
You are probably getting an error beep, codes are on page 15 of the Drivers Ed Guide. https://dzf8vqv24eqhg.cloudfront.net...95-0290-00.pdf | |
05-10-2018, 08:12 PM | #165 | |
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) Nope. That beep was disabled as well. Quote:
Robert, do you think the Micro X would be safe on an SCX10 II with a 35T brushed motor? | |
05-11-2018, 08:36 AM | #166 | |
I can compare against other products though. The Holmes BR Mini has 8 MOSFETs. The Micro X has 6 but only uses 4 of them in brushed mode. The Micro-X also has a heatsink, which would help out. I see that Holmes rates the BR Mini as 30 amps continuous and 60 amps peak, so with half the MOSFETs and and heatsink, I would expect the Micro-X to do 20 amps continuous and 40 amps peak by JRH's ratings. You could use your Mamba X's datalogs to see how much current the motor was using. | |
05-11-2018, 08:44 AM | #167 | |
05-11-2018, 11:23 AM | #168 |
the micro x would run a 35t on 3s just fine with reasonable stock gearing. 27t might run it ragged on 3s, it depends on the driver and terrain and if they threw 3 pounds of scale accessories on.
05-11-2018, 12:13 PM | #169 | |
I also just realized there are two version of the Micro X. So which one are we talking about and what are the differences - besides the soldering posts? Castle's site lists the MAMBA MICRO X 12.6V ESC, 2A PEAK BEC W / POSTS and MAMBA MICRO X EXTREME 1:18 SCALE ESC Last edited by JatoTheRipper; 05-11-2018 at 01:10 PM. | |
05-11-2018, 02:20 PM | #170 | |
05-15-2018, 12:49 PM | #171 |
Quarry Creeper Join Date: Dec 2012 Location: okc
how do I determine what Kv castle slate motor to get? scx10ii for slow crawling, hill climbing, some trail running but not fast
05-15-2018, 12:57 PM | #172 |
Rock Crawler Join Date: Nov 2014 Location: Dells
1900kv 3/4s only 2280kv quick on 3s, slow on 2s 2850kv fast on 3s, decent on 2s Iv rn both the 2290kv and 2850kv on 3s with the microx without issue |
05-15-2018, 12:59 PM | #173 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
I'd go 2850.
05-15-2018, 01:41 PM | #174 |
Quarry Creeper Join Date: Mar 2018 Location: Park Hills
I'm running a Mamba X with 2850kv slate motor on stock bomber gearing (14T pinion 64T spur) and my Bomber is a fatty at 9.5LB, on 3s LiPo I've only seen motor tempts in the low 100's so far this spring. The 2850kv is pretty darn fast in high gear 1:1, I have the SSD 2 speed kit, so it's got a nice 2.34:1 low gear for crawling. The Aux wire from the Mamba X is really nice to toggle drag brake/rock race mode for low and high gear! It's a must for any 2 speed crawl and bash setup. I also run the BEC at 6v and have never had any brownout isseus with m Savos 1283 like I did with the axial esc. |
New Castle Mamba X (sucessor of Mamba Max Pro) - Similar Threads | ||||
castle mamba max pro help | bcgal0004 | Axial Wraith | 5 | 04-05-2012 07:41 AM |
