01-28-2017, 11:10 AM | #101 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: New Castle Mamba X (sucessor of Mamba Max Pro)
I ran my Mamba X Thursday with the brushed motor (HH 16T Crawlmaster Pro). It started acting like it hit lipo cutoff so I swapped batteries. We checked the voltage Pilot_MM's lipo checker thing and it was at 10.86 IIRC. He had left before I finished the next pack, but when I hooked them up to my charger at home, one pack was sitting at ~3.6-3.75v per cell and the other pack was all at 3.8-3.9v per cell. My cutoff is set at 3.2v. I spoke with someone at Castle who said that it was normal to have voltage that high after sitting a while, but I cant recall ever having it that high after hitting cutoff on my other 6 Castle ESCs. I would check the logs, but it deleted them...I set it up to delete at 90%, but I ASSumed that I would be able to pull data after I shut the ESC off as long as I didnt actually turn it back on before hooking up to Link. |
01-28-2017, 11:51 AM | #102 |
Rock Crawler Join Date: Nov 2014 Location: Dells
It could be the batteries are starting to go. They may be 3.9v just sitting, but with a load they drop to 3.2 or lower.
01-28-2017, 12:04 PM | #103 |
They are both new packs. Turnigy Nano Tech 1500mah 35-70C. Everything electronics wise except my RX is new. Next time I get a chance to go out, I'm going to take a couple other batteries with me. I was just curious if anyone else had a similar experience with this ESC yet. |
01-28-2017, 01:23 PM | #104 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Is it cold in Vegas or where you were running?
01-28-2017, 02:03 PM | #105 |
being turnigy it is possible they came that way from the factory.
01-31-2017, 09:19 AM | #106 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) Yes, we are working through the process of discontinuing the MMP and sensorless motors. We will still continue to support the product and will still be building for third party options of it(Holmes, Traxxas, ect... ). We may also continue to sell the 1 cell as there is no plans to make a Mamba X 1 cell at this time.
01-31-2017, 10:09 AM | #107 | |
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) Quote:
An extreme example of how much packs can sag in voltage is when we were testing the Mamba Monster for use in the Traxxas E-revo with NiMH packs we found under hard accelerations the packs would drop from 16.8V to ~2V and it was causing the processor on the ESC to reset. With a brushed motor in a crawler you are never going to pull that many amps, but if your pack is half discharged and doesn't have the grunt to keep up, it might fall below the 3.2v per cell. If this is a consistent problem you could lower the cutoff to 3.0v per cell. Then again, this could be another firmware issue. We don't do very much testing of brushed mode(obviously since we never checked if the stock firmware could run one). The sidewinder sv3 had an issue where it would never do low voltage cutoff in brushed mode and that firmware was out for 3 years before someone noticed. | |
01-31-2017, 06:58 PM | #108 | |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
01-31-2017, 07:01 PM | #109 |
Rock Crawler Join Date: Nov 2011 Location: Asheville
Is there a trade up program from mmp to mamba x? Sent from my SM-G900V using Tapatalk |
02-01-2017, 12:00 AM | #110 |
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) You would need to talk to the guys in tech support(Joe, Thomas, Jason) or the ladies in sales(Rebecca, Jenny) about that one. I assume there will be one eventually if we don't already have one. We had one for the other X series controllers, so it would shock me if we didn't do it again.
02-01-2017, 12:01 AM | #111 |
Quarry Creeper Join Date: Aug 2016 Location: Christiansburg
Just ordered one through my LHS. Now to plan the motor... |
02-01-2017, 12:07 AM | #112 |
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) For both us and our distributors limiting the number of SKU's is important because for every SKU we have to keep a certain amount in stock on the shelves of distributors so they can supply hobby shops and we have to keep a certain amount in stock for direct sales. Every product that is sitting on a shelf costs both companies money, so it is essential to limit the number of products we have to keep overhead costs as low as we can. We will keep replacement stock for repairs and warranty for a few years, but fully packaged new units will likely start to disappear from shelves soon as they sell out.
02-01-2017, 04:21 PM | #113 |
Hell yes. Can't wait to run this sucker.
02-04-2017, 10:17 AM | #114 |
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) |
02-04-2017, 10:48 AM | #115 | |
I may be switching this truck back to brushless too...I've gotten spoiled by the power. | |
02-05-2017, 09:34 AM | #116 |
Pebble Pounder Join Date: Feb 2014 Location: Hampton Roads
Will this esc be ok paired with an 1/8th scale motor like the new sensored 2650 motor since the esc is 1/10th scale?
02-05-2017, 10:37 AM | #117 |
Ask castle, you might think the bigger MMX..... Hang up and Drive |
02-05-2017, 10:47 AM | #118 |
02-06-2017, 07:39 AM | #119 |
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) Depends on the setup, it might be. The ESC for use with the 1512 motors in 1/8th scale buggies. We have not tested the ESC with a bomber or yeti with the 1/8th scale motors, but I imagine that it would probably be just fine.
02-08-2017, 12:00 PM | #120 |
| Re: New Castle Mamba X (sucessor of Mamba Max Pro) Any chance it could be tested with a yeti? That's what rc I would look at putting this in and running. Bashing around the yard, jumping, trails and up n down the road.
New Castle Mamba X (sucessor of Mamba Max Pro) - Similar Threads | ||||
castle mamba max pro help | bcgal0004 | Axial Wraith | 5 | 04-05-2012 07:41 AM |
