07-25-2017, 01:44 PM | #1 |
Newbie Join Date: Mar 2017 Location: Toronto
| DX4C 4Ch radio switch for LED lights won't work
Hi guys, I just installed my 2 LED bar for Gmade R1: R1 LED Lightbar (2 Lights) [GM51408S] : JunFac.com I have DX4C 4Ch Radio: DX4C DSMR 4CH Tx w/SR410 - Hobby Hobby I was wondering how I can switch on/off the lights using the switch on the radio. I already tried going to the radio "switch" menu to change one of the buttons to AUX 1 2P and yet, no response. Please help. Thanks, |
07-25-2017, 03:01 PM | #2 |
Rock Crawler Join Date: May 2013 Location: Uniontown
| Re: DX4C 4Ch radio switch for LED lights won't work
You need a light controller, HeyOK are what I would suggest looking into. Sent from my XT1585 using Tapatalk |
07-25-2017, 03:03 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
Not sure you can make it work the way you have it but I know that heyok makes a couple switches that do what you want. HeyOK Remote Switch for LED Lighting HeyOK External Power Remote Switch for LED Lighting |
07-25-2017, 04:28 PM | #4 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
Try 3p
07-26-2017, 08:28 AM | #5 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
You must have a switch between the rx and lights to turn them on and off, Heyok makes great ones. You can also use an old servo board. A Pico switch is another option, DSPro sells those. The light is just power and ground, there is no signal wire going to them, your rx is always powered when the battery is plugged in. That is why they are on always, when you add a switch in the mix it turns the power on and off by adding a signal wire so tx can talk to the rx. This will turn your lights on and off via the tx. Set up that channel to a 2P and you will be gogd to go. Last edited by hotwheels000; 07-26-2017 at 08:32 AM. |
07-26-2017, 03:20 PM | #6 | |
Thanks everyone for pointing him towards my products. Please send me a PM if I can help you directly. Quote:
DX4C 4Ch radio switch for LED lights won't work - Similar Threads | ||||
Third channel led lights switch & other newbie questions | devuser | Axial SCX-10 | 1 | 06-14-2016 11:13 AM |
DX4C and lights | Nugget04 | Electronics | 2 | 03-19-2015 05:10 PM |
LED lights on a single HeyOk switch | SoCal_80 | Axial Wraith | 2 | 01-25-2015 08:24 PM |
SCX10 TR - how to control stock led lights controller via 4CH TX | Le0Heart | Axial SCX-10 | 9 | 01-13-2011 08:03 PM |
How can i tell if a 4ch stick radio will work? | BEELZEBOB | Newbie General | 5 | 02-12-2009 08:41 AM |
