Thread: Problem with a Holmes HV500 Servo
Old 10-16-2017, 12:24 PM   #1
Question Problem with a Holmes HV500 Servo
I have contacted Holmes twice over the last couple weeks through their website but have not gotten a reply, don't know if my question just didn't go through or what but I am looking for some advice.
I am having a problem with my HV500 I am hoping you can help me with. I have not pulled the servo apart yet to see if there is anything wrong on the inside but I have checked the BEC and tested the servo without it, still acts the same. I have also checked all the connections and cleaned them. I am running a Holmes bypass with the Castle BEC. The servo stutters sometimes and it can "hang up" on returning to neutral and take a second to return or can stutter when turning slowly. I have unhooked the steering linkages and there is nothing binding. I have also tried another servo and it works normally.
I have included a link to a private video that I uploaded to my YouTube channel that shows the problem. If you have any problems viewing it please let me know. The humming in the video is a fan I run on the ESC, never needed it but like insurance on a long trail run.
https://youtu.be/YIPcdBAv020
Hopefully there is something I can easily do to fix this servo. Going to take this opportunity to tear down and clean/relube the truck while it is down. Hopefully someone can give me some advice before I tear the servo apart so I know what I am looking for.
Thank you for your time.
Prime is offline   Reply With Quote
Old 10-16-2017, 12:57 PM   #2
Default Re: Problem with a Holmes HV500 Servo
Sounds like dirt in the pot, but JRH knows far more. Usually takes a couple of days thru the website, but Erin or Justin will get you hooked up.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 10-16-2017, 10:04 PM   #3
A dirty pot sounds like it is probably an easy fix. Thanks, hopefully they will chime in on this.
Old 10-17-2017, 02:58 PM   #4
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Tis likely a broken center pin. take the six screws off the face and check.
Old 10-17-2017, 07:01 PM   #5
Thanks for the heads up. I took apart the servo and all looks good in the top of it. Here is what the top looks like on the inside. Will remove the bottom next.
Servo
20171017_203336
20171017_203703
Old 10-17-2017, 07:41 PM   #6
Found the problem in the bottom of the servo. Looks like the gasket was not installed correctly and let water in and it killed the motor. Sad day, I really liked this servo, it served me well.
Can see the gasket and where water got around it since it was not in right.
20171017_211330
With the flash can see the goop/rust by the motor.
20171017_212142
Problem with a Holmes HV500 Servo - Similar Threads
Verdict on Holmes Hobbies HV500 Servo? Drm31078 Axial RR10 Bomber 5 05-09-2016 10:36 AM
