01-15-2018, 05:52 PM | #1 |
Pebble Pounder Join Date: Jun 2014 Location: MA
| Mamba X Rock Racer/Crawler feature question
I have been tinkering with this feature and have not been able to achieve my desired result. What I would like is the ability to switch between crawler mode where I can use forward and reverse without nuetral delay including drag brake, and rock racer mode where I get forward with brake and reverse after delay plus drag brake. am i missing something? Is this possible? Forgive me if this has been answered elsewhere! |
01-16-2018, 03:28 PM | #2 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Mamba X Rock Racer/Crawler feature question
You can only have rock racer mode with reverse (delay), no drag brake and crawler mode with crawler reverse (instant), with drag brake.
01-16-2018, 03:48 PM | #3 |
Quarry Creeper Join Date: Jun 2016 Location: Tacoma
That's doable. I have my TRX-4 setup to use the AUX wire to switch between Crawler and Rock Racer modes. Its piggy-backed off my transmission high/low gear button so low gear = crawler mode with drag brake, high-gear = Rock Racer with brake and delayed reverse. *Edit* There's no drag brake in rock racer mode. |
01-17-2018, 07:49 AM | #4 |
Thanks guys, i can live with no drag brake in rock race mode. tuanies thats a really cool idea to have it set with your hi/low gear.
01-17-2018, 08:48 AM | #5 |
| Re: Mamba X Rock Racer/Crawler feature question |
01-17-2018, 10:37 AM | #6 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: Mamba X Rock Racer/Crawler feature question X-series Rock Race/Crawler Auxiliary Wire Mode There are examples there with the drag brake available in the racer mode. It will be reduced, but it will work. I have my aux wire connected in parallel with the shifter servo, and zero drag brake in racer mode. |
01-17-2018, 02:14 PM | #7 |
I requested the removal of drag brake and instant reverse when toggling from crawler mode to rock racer mode. I would forget I was in this mode when going fast and when I hit the brake it would go into reverse and do a forward roll. |
01-17-2018, 03:15 PM | #8 | |
| Re: Mamba X Rock Racer/Crawler feature question Quote:
01-17-2018, 03:41 PM | #9 |
You should be able to achieve this. (what I explain below is for a 3 position setup, ignore the mid point if using a 2 position setup) For the Aux channel used the setting for low will be the drag brake value for Rock Racer mode (if this value is set above 0% rock race mode will have a drag brake) the trim is the mid point and sets the value of the drag brake in Crawler mode for the medium setting, and the High will be the max drag brake setting for crawler mode when switched to high. In the Castle link settings you would need to set the drag brake to a value between the low and mid points, what you set this to determines when the switch between Crawler and Rock Race mode occurs. If its set to 25% in Castle link then below 25% you will switch to Rock Racer Mode, over 25% you get crawler mode. This thread has tons of good info in it too. Mamba Firmware V2.02 Last edited by HumboldtEF; 01-17-2018 at 03:44 PM. |
01-17-2018, 03:53 PM | #10 |
I can do what I need. Castle added it to the firmware. It wasn't possible in the beginning. Sent from my SM-N910V using Tapatalk |
Mamba X Rock Racer/Crawler feature question - Similar Threads | ||||
Very hot motor question on rock racer conversion | oo C64 oo | General Crawlers | 7 | 04-28-2015 04:36 PM |
Rock Racer or Crawler | aceisback | Vaterra Twin Hammers | 13 | 03-21-2013 09:18 AM |
Rock Racer vs Crawler | klamp | Newbie General | 7 | 06-22-2011 12:37 PM |
Rock Racer to Rock Crawler Conversion | Orgnoi1 | Axial AX-10 Scorpion | 9 | 03-06-2010 10:07 PM |
Rock racer Question | twors | General Crawlers | 22 | 06-06-2008 07:52 PM |
