02-11-2018, 10:38 AM | #1 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| run servo directly off battery pack
I have a "crawler" that uses a Traxxas ESC, which has a BEC that recently decided it didn't want to work properly anymore. the only thing stopping me from running the servo directly from the 2S battery, is that I don't know what the servo will do before i turn on the ESC and receiver. so, what do most servos do when they receive voltage but no signal from the receiver?
02-11-2018, 11:47 AM | #2 |
| Re: run servo directly off battery pack
I think the first thing you need to do is verify the servo input voltage limit. Can it handle 7.4v direct?
02-11-2018, 03:34 PM | #3 |
I'm gonna be buying a new ProModeler, the previous Savox seems to be toast.
02-11-2018, 03:52 PM | #4 |
Rock Crawler Join Date: May 2016 Location: SoWIs
Most servos will do nothing, but it really depends on the MFG. If you have any other ESC that works, you can test it out. Power the receiver via ESC and run the servo with the white or orange wire removed from the plug.
02-11-2018, 03:54 PM | #5 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Promodeler DS470BLHV could support up to 8.4V
02-11-2018, 07:31 PM | #6 |
| Re: run servo directly off battery pack |
02-11-2018, 11:03 PM | #7 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
You can power it off the ESC too to see what happens. Just remove the white wire from the plug first. Anyway, depending on servo, ESC and Tx, some of my models center, some go to one side, some do nothing when turned on. My guess is it's gonna depend on circuit inside servo. |
02-11-2018, 11:50 PM | #8 |
I'm just gonna email John and ask Sent from my Nexus 5 using Tapatalk |
02-12-2018, 12:15 PM | #9 |
He says he doesn't know, but it shouldn't do anything. Sent from my Nexus 5 using Tapatalk |
run servo directly off battery pack - Similar Threads | ||||
Servo directly to battery | papabash | Losi Mini-Rock Crawler | 9 | 12-08-2011 02:51 PM |
Run servo off 7.2 pack? | rottenbelly | Electronics | 1 | 10-05-2008 03:58 PM |
Drew a diagram to run a servo pack | Brainstain | Electronics | 2 | 08-25-2006 01:15 PM |
Battery pack for two 1/4 scale servo ?? | Benlatak | Electronics | 2 | 04-30-2006 02:58 PM |
servo problem?? reciever battery pack? | TwistedCreations | General Crawlers | 13 | 03-28-2004 06:59 PM |
