02-19-2018, 11:46 AM | #1 |
Rock Stacker Join Date: Feb 2008 Location: Shingle Springs, CA
| GT3C - increase servo throw
Hi all. I'm not sure this is even a thing, but wanted to ask anyway. I have a stock GT3C that I use with my SCX10 II. I am interested in learning if it's possible to increase the throw (rotation?) of the servo. The servo I have is supposed to be capable of 180º, but I seem to get around 140ish (just an estimation). Servo here: https://www.amazon.com/gp/product/B0...&tag=pda0fc-20 Anyhow - I have tried using the RCC search, as well as Mr. Googley. My issue is that I may not be searching for the right terminology - OR - what I'm asking for is impossible...heh Thanks in advance all! -Moddy |
02-19-2018, 12:06 PM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: GT3C - increase servo throw
What you need is to adjust the endpoints of the ch. Don't know the range I think it's limited to.max 120% Send by my Pixel 2 XL with Tapatalk |
02-19-2018, 12:28 PM | #3 |
| Re: GT3C - increase servo throw |
02-19-2018, 01:22 PM | #4 |
Rock Crawler Join Date: May 2016 Location: SoWIs
The advertised servo angle is misleading, it's like saying a gearbox can withstand 1000hp but hooking up an ordinary V8 doesn't mean you get 1000hp. A typical radio gives you 90 degrees at "100%" and 108 degrees at "120%", regardless of it being a standard or 180* servo. I have noticed a 90* signal will result in 90* on some servos and >100* on others. IF your radio can provide 200%, then you'll get 180* of twist and full resolution. To get 180* with a normal 90* TX you need a module that "doubles" the RX's output range or mod the servo, but resolution will be halved with those methods. I've never seen a servo angle extender, but I've considered making them. To mod the servo you must add resistors to the outer legs of it's pot. I did this many moons ago to a Cirrus but do not recall what the values were. |
02-19-2018, 01:28 PM | #5 | |
| Re: GT3C - increase servo throw Quote:
Sent from my SM-G935V using Tapatalk | |
02-23-2018, 04:35 PM | #6 |
You need to get a widget to expand the servo signal. Such as https://www.servocity.com/180-servo-stretcher 180º Servo Expander - Flytron https://www.mr-rcworld.co.uk/shop/18...mera-expander/ |
02-23-2018, 04:40 PM | #7 | |
Tags |
increase angle, increase throw, servo, throw |
GT3C - increase servo throw - Similar Threads | ||||
Not enough servo Throw | High Angle Five | Electronics | 13 | 06-30-2017 06:18 AM |
Servo throw | billy bones | Electronics | 4 | 05-24-2015 09:26 PM |
Servo throw. | billy bones | 1.9 Scale Rigs | 4 | 05-24-2015 04:04 PM |
servo throw | desertrunner | General Crawlers | 2 | 05-27-2010 04:47 PM |
Steering Throw Increase? | FireWire79 | Losi Micro-Rock Crawler | 3 | 03-22-2010 10:41 AM |
