02-27-2018, 04:29 PM | #1 |
Newbie Join Date: Dec 2017 Location: Moncton
| Not enough power going to my servo.
Having issues getting full power to my servo. Running a savox servo on my scx10.2 with a 53000mah 3s lipo. When the truck is parked on rough terrain, or I'm on a tough obstacle and need to re arrange my steering, the steering won't go full cut. And that's with a full charge. What's wrong?
02-27-2018, 04:58 PM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: Not enough power going to my servo.
You may need a BEC or a stronger servo. Which model is it?
02-27-2018, 05:12 PM | #3 |
Honestly not entirely sure. I'd have to check when I get home. It's the solid blue water proof one if that says anything. What exactly is a BEC? I've heard of it but it's never been explained to me before, and what brand do you suggest?
02-27-2018, 05:16 PM | #4 |
| Re: Not enough power going to my servo. |
02-27-2018, 05:28 PM | #5 | |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: Not enough power going to my servo. Quote: CC BEC 2.0 Waterproof Voltage Regulator Also, consider putting that money towards a new esc with a higher amperage internal bec (castle mamba x). Less space and less wiring. | |
02-27-2018, 05:39 PM | #6 |
Before you buy anything, what is the amperage of the internal bec on your current esc? When you stall the servo, does the control of the throttle go out as well ("brownout")?
02-27-2018, 05:42 PM | #7 | |
02-27-2018, 06:40 PM | #8 | |
When I switched from the stock esc w/external (castle 15A) bec to the Mamba x it was really nice to have so much less wires to stash away. And it is an awesome esc. But the old external bec will be used in my bomber, so will not go to waste. It depends on what your priorities are. | |
02-27-2018, 06:49 PM | #9 | |
02-27-2018, 09:06 PM | #10 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
If you are running the original Axial AE-5 ESC, the internal BEC output is 5V. Today's high torque, high voltage servos suffer terribly with low voltage supply to the servo. Check the specs on most high torque servos and note the torque rating change from low voltage to 6V, 7.4V or even higher voltage. Caution though, don't exceed the maximum voltage listed by the manufacturer. That's the advantage of the external BEC, you can set the voltage to the highest recommended by the manufacturer.
02-27-2018, 10:52 PM | #11 | |
This is where an external BEC can have value, if you have an rx and/or a shifting or winch servo that is limited to 6V but you want to run the steering servo at 7.4V or higher; you can wire the external bec to only power the steering servo as I did with my son's Summit. I run the factory tactic rx at 7.4V without problems, but the powerHD servo I tried at that voltage stopped working and smells smokey. | |
02-27-2018, 11:48 PM | #12 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Your servo might just be underpowered. Either it doesn't have enough oomph, or it isn't getting the power that it needs. You need to know the model # and torque specs. If you're not looking to spend big bucks on an ESC, the Hobbywing 1080 is great. It is pretty adjustable, small, waterproof, and has a good internal BEC. Best of all, you can pick it up for about $45. | |
02-28-2018, 03:35 AM | #13 |
Yeah, if you're sticking with brushed, the 1080 is more than enough. It has a 6/7.4 adjustable pwm BEC that's rated for "only" 3A but the rating seems very conservative. But if it's the blue Savox wp servo I think it doesn't have enough torque to turn the wheels on a grippy surface when not moving anyway... Last edited by Ninomaniac; 02-28-2018 at 03:40 AM. |
02-28-2018, 04:13 AM | #14 |
If my servo is just under powered.. what is a good powerfull servo I could buy? I thought savox were good servos
02-28-2018, 04:46 AM | #15 |
they are good servos, but there's torque, speed, precision, programmability, waterproofing, brand name, all of that stuff determines price. look for around 30kg or 400oz, plenty of threads on servos around here. |
02-28-2018, 06:39 AM | #16 |
Time for a better ESC unless you wanna dick around with an external BEC.
02-28-2018, 07:23 AM | #17 |
When I bought my servo I was told it could run at 6v and 7.4 at 90oz and 111.2oz
02-28-2018, 08:34 AM | #18 |
that's fine... for a touring car or maybe a 2wd buggy |
02-28-2018, 10:22 AM | #19 | |
The 'blue' Savox SW1210SG that I use is waterproof and at 7.4 volts it produces .13 sec/319.40 oz-in. I know many here would consider this to be a minimum requirement. | |
02-28-2018, 11:30 AM | #20 |
That servo just isnt strong enough for a crawler. 300oz in would be minimum, but 400+ would be better. Hitec 7955s are a good choice.
Not enough power going to my servo. - Similar Threads | ||||
Servo power | redneckracerx | Electronics | 9 | 09-19-2016 05:43 AM |
More power to your servo | twissted | Electronics | 14 | 02-22-2015 11:32 PM |
servo power | ridgewalker | Electronics | 2 | 06-05-2007 10:59 AM |
High Power BEC/Servo Power Supply | MANTIS | Electronics | 14 | 08-09-2006 03:33 PM |
servo power? | Emaxximuss78 | Electronics | 4 | 05-23-2005 01:29 AM |
