03-23-2018, 08:02 AM | #1 |
Rock Stacker Join Date: Feb 2018 Location: Pan Handle
| RE: Motor and ESC help
I am getting a Losi Rock Rey not quite monster truck or crawler. I am having trouble with the 550 motor size. Can anyone recommend a good motor/esc combo? 2s-3s. Seems this 550 size motor and 4-6 pole gets confusing. Not sure if it is worth the extra $$ to go sensored or not. I have only ran 1/8 truggys for the past few years on and off. Would the Castle Mamba Max setup I have in my 1/8 truggy be too much for this 1/10 scale truck? Thanks.
03-23-2018, 08:13 AM | #2 |
| Re: Motor and ESC help
Check out Team Brood Racing. I made the same suggestion to Arctic Cat ZRT and last I heard he was very happy with the motor. Here's his thread: Cat's Rock Rey |
03-23-2018, 08:16 AM | #3 |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
If you're planning on crawling with it, sensored is worth it. For general bashing, not so much. One of the things to keep in mind is you want a motor with a 5mm shaft for the Rock Rey. If you were going to run 3S and/or wanted slower speeds, you'd probably want a motor with lower KV. And again, get sensored for crawling. Last edited by TooOldForThis; 03-23-2018 at 12:28 PM. |
03-23-2018, 08:43 AM | #4 |
I will not be doing any racing just bashing and would like to try some crawling
03-23-2018, 11:53 AM | #5 |
Holmes Hobbies Puller Pro XL motors would also be an excellent choice...
03-23-2018, 12:31 PM | #6 |
| Re: Motor and ESC help Done. Now what am I supposed to do about the fact that you quoted it? A PM would've been a lot more appropriate.
03-23-2018, 12:34 PM | #7 | ||
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Motor and ESC help Quote:
Ernie | ||
03-23-2018, 05:02 PM | #8 |
Rock Crawler Join Date: May 2016 Location: SoWIs
If you don't mind undergearing it, a sensorless motor will be fine if you get a decent ESC. An overgeared sensorless motor with a cheap ESC will most definitely cog at low speed. If you were used to a 1/8 truggy, chances are you will not have fun bashing at 5mph. I'd highly recommend focusing on the ESC before the motor. A cheap sensored motor will crawl fine with a good ESC, but not vice versa. Cheap motors are only 5-10% less efficient than motors 3x their price. Also be aware that sensored motors are NOT waterproof unless specifically noted. Sensorless & brushed are about 99% waterproof, but not dirty water proof. |
03-24-2018, 06:19 AM | #9 |
Thanks for all the info. Seems like I have lots of options. What do you think about this combo? Its under $200 MAMBA X, 25.2V WP ESC AND 1406-3800KV SENSORED COMBO |
03-24-2018, 06:20 AM | #10 |
It looks like two motor options in 5MM shaft... 2400Kv and 3800Kv.
03-28-2018, 02:51 PM | #11 |
Quarry Creeper Join Date: Nov 2014 Location: Reno
I run a Mamba X With a Tekin pro4hd 3000kv . I mostly crawl and trail with mine. All the power u could ever want with a super smooth start up Sent from my SAMSUNG-SM-G920A using Tapatalk |
RE: Motor and ESC help - Similar Threads | ||||
Sidewinder esc and 5700 motor or Traxxas vxl 3s esc with brushless motor? | THE CRAWLER KING | Newbie General | 6 | 08-22-2010 07:10 AM |
single motor esc or dual motor esc | jwo | Electronics | 0 | 01-20-2010 11:42 PM |
