Thread: Tactic tr325
Old 04-24-2019, 12:39 PM   #1
Exclamation Tactic tr325
Hello i run axial scx10.2. I have tactic tr325 receiver and tactic ttx200 controller. All of the sudden it stopped working... no throttle, no steering receiver doesnt blink, it makes only two beeps when powered on instead of three beeps. When trying to bind the controller again, it doesnt work. Reciever wasnt in contact with Water... Any ideas?
Doro is offline   Reply With Quote
Old 04-24-2019, 12:43 PM   #2
Default Re: Tactic tr325
did you have the receiver unplugged and maybe intentionally reversed all the servo/esc cables? If not that, may have burnt up via too much power
DukeMinnix is offline   Reply With Quote
Old 04-24-2019, 12:46 PM   #3
Try recalibration not re binding.....
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 04-24-2019, 01:05 PM   #4
Your ESC may be dead, what is it?
Sent from my SM-G960W using Tapatalk
MasteroFlego is offline   Reply With Quote
Old 04-24-2019, 01:12 PM   #5
Nope... I didnt mess with cables..
Old 04-24-2019, 01:14 PM   #6
Hang up and Drive
Its self calibrating so i cant calibrate it manually.
Old 04-24-2019, 01:15 PM   #7
Why do u think esc? I thought its either controller or reciever...
Old 04-24-2019, 01:20 PM   #8
Esc powers the reciever. Try unplugging and replugging esc wire in reciever, may be it came loose.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Steve g is offline   Reply With Quote
Old 04-24-2019, 01:41 PM   #9
Wires Are good, reciever is powered because when trying to bind again it blinks... But the light doesnt stay on like its in the manual..
Old 04-24-2019, 01:51 PM   #10
First Test the battery or replace it with a known fresh charged
Second are you running 3s, as you mentioned 3 beeps.
What ESC are you powering? is polarity correcton rx(brown wire is ground)
Channel 1 is to steering servo, channel 2 is for throttle. Make sure both brown?black wires are in the negative slot
Old 04-24-2019, 01:53 PM   #11
Is your transmitters throttle trim set in the middle?
Old 04-24-2019, 02:19 PM   #12
I have not had a ttx 200 only the ttx300. But when my receiver went out, it had a solid red light, no noises. The problem is probably not throttle trim, throttle trim issues I have not seen effect steering. I believe the 2 beeps you hear are coming from the ESC and not the receiver. the esc beeps according to the voltage not the receiver, as the receiver runs off a bec that is usually a lower voltage then 2s. Are there any lights on the receiver? cant find mine at the moment
Voodoobrew is offline   Reply With Quote
Old 04-24-2019, 02:30 PM   #13
I got it guys..... Problem is with the stock servo. As soon as i disconnect the driving servo throttle start working... I found some guys experiencing the same peoblem. After replacing servo the problem was solved..
Old 04-24-2019, 03:19 PM   #14
Natedog's Avatar
All good suggestions.
Hahaaha, I was going to mention that lately a dead steering servo has been the cause of quite a few esc/rx problems from the threads I've read. Glad you got it sorted.
Tags
issues, reciever, tr325
Tactic tr325 - Similar Threads
tactic tr325 issue. Bmxreeves Electronics 9 04-03-2017 01:39 PM
Tactic Tr325. Cannot remember which plug is what MaFoDes Electronics 2 07-17-2016 05:50 AM
Tactic tr325 reciever hvydty1 Electronics 1 05-11-2016 09:26 PM
