Thread: Electronic failing
Old 05-07-2019, 07:32 AM   #1
Default Electronic failing
Hello guys,
I will try to explain my problem as good as I can...
Ive a waterproof esc like goolrc, from China.
After months with the rig stopped due axles upgrades, the esc doesnt beep when I switch it on as usual, it sounds like a going down beep... also the tactic receiver is blinking and it’s not possible to do anything to pair or whatever...
I guess I blew up everything but still don’t know how, why...
Do you know the meaning of this go down beep?? I didn’t find anything like this in the esc manual.
Enviado desde mi iPhone utilizando Tapatalk
SpaniardCrawler is offline   Reply With Quote
Old 05-10-2019, 01:15 PM   #2
Default Re: Electronic failing
Unplug the servo, then check if motor works.
Look in motor holes for black wire, that's generally bad.
Try to isolate components as best you can to eliminate problems.
Sent from my SM-N950U using Tapatalk
Voodoobrew is offline   Reply With Quote
Old 05-10-2019, 02:26 PM   #3
Unfortunately, the no name esc's are very hit & miss. My son had a brushless "GoolRC" esc fail after 2 outings, several other friends have had them die in short order too... but their motors seem fine (not much to them.) I've had bad luck with the pre-installed T plugs that don't seem to make a good connection until you plug/unplug the battery several times, switching to genuine Deans plugs (or your plug of choice) cures that issue. That being said, there's still a chance that it's just a faulty power switch, in which case, you can just cut it off, solder the 2 wires together, and it will effectively always be switched on (your battery will become your power switch.) I'd start there.
TheLetterJ is offline   Reply With Quote
Electronic failing - Similar Threads
HH electronics simultaneously failing...... need help! Pgambardella Electronics 19 01-04-2014 08:40 AM
how often are your pc's failing/running poorly? thecrusader Chit Chat 25 11-11-2009 12:18 AM
electronic help rckcrawler Electronics 3 05-29-2008 10:47 AM
Damn Lockers Keep Failing! Vendors Please Make Steel Ones! kawika Axial AX-10 Scorpion 20 01-27-2008 08:18 PM
