Thread: My trick RC controller questions
Old 07-21-2019, 10:00 AM   #1
Default My trick RC controller questions
I have a Team Associated LED set installed on my trx4. After a couple months, the controller box started to act stupid. Random flashing lights, no more mode adjustability.
So I bought a MyTrickRC U7 light controller to use with the existing LEDs. It was the only one I could find that used the same tiny plugs to connect the LEDs. I cannot get anything to light up. I have tried the 9v battery and connected to the bec. The controller shows it is on and flashes thru all the mode settings but no LEDs come on.
Any ideas ? I'd rather not rip out all the LEDs.
PS, MyTrickRC does not respond to support emails.
chipgibbs is offline   Reply With Quote
Old 07-21-2019, 10:20 AM   #2
Default Re: My truck RC controller questions
I'm no electrical guru. But my first thought is that your LEDs want (for example) 5 volts and the controller is only giving 3 volts. Maybe check output voltage of both controllers?
vf750rider is offline   Reply With Quote
Old 07-21-2019, 10:22 AM   #3
I'm going to bet that the lights were only rated for 6v, and your new controller gave them too much voltage.
Otherwise I'm not sure without seeing them.
Sent from my Pixel 2 using Tapatalk
brimdogg is offline   Reply With Quote
Old 07-21-2019, 10:24 AM   #4
Could also be this, not enough voltage can do the same thing.
Test what the new controller gives for voltage.
Old 07-21-2019, 10:59 AM   #5
or the positive and negitive leads could be backwards from one brand to the other
ferp420 is online now   Reply With Quote
Old 07-25-2019, 01:18 AM   #6
Default Re: My trick RC controller questions
I don't think the uf-7 has a 12v output so probably did not over volt the leds. I would check polarity. read instructions if you can find them as well. you can probably pop them out of the plug with a razor knife and swap them.
Voodoobrew is offline   Reply With Quote
My trick RC controller questions - Similar Threads
BEC as Light Controller With Remote Switch Questions Hardcoretam Electronics 5 04-24-2017 05:32 PM
Motor, esc hooking up: reverse and controller 2 questions EZGoing486 Newbie General 5 12-26-2015 10:37 PM
REVS electronic questions, servo & controller! REV666 Electronics 5 03-08-2013 03:49 AM
Next scale truck / tough truck questions. boisetrucker Idaho 2 03-17-2012 09:24 PM
speed controller for stadium truck pontiacfreak Non Crawler RC's 8 01-31-2010 08:36 PM
