Thread: Reciver signal strength
Old 08-30-2019, 07:59 PM   #1
Default Reciver signal strength
This is a general question for receivers. How far can a reciver send a signal though the wires?
Say if you have a 6v reciver pack and 50ft signal wires to a couple esc and servos powered by an bec. At what point does the internal resistance of the wire have an effect.
Just some crazy project that popped into my head while I’m trying to go to sleep.
Sent from my iPhone X using Tapatalk
toka100 is offline   Reply With Quote
Old 09-03-2019, 05:16 PM   #2
Default Re: Reciver signal strength
It's going to depend on wire size, voltage and wire resistance. Probably also trial and error. Since the signal is just off and on it will probably be much further than something like an analog video signal. There are probably a bunch of electrical calculators for this, but nothing is as accurate as trial and error.
Sent from my SM-N950U using Tapatalk
Voodoobrew is offline   Reply With Quote
Reciver signal strength - Similar Threads
no signal.... dannyboyjdc Newbie General 6 10-18-2016 05:54 PM
NO Signal dubAron Electronics 2 01-26-2011 12:31 PM
What's the output signal from an Rx? clockworks Electronics 8 08-11-2009 05:16 PM
no signal? bigblazerboy Electronics 0 02-23-2008 03:39 PM
RX not getting signal rckjeep Electronics 6 02-10-2005 12:32 AM
