12-10-2019, 10:12 AM | #21 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Reverse servo polarity?
Someone in the TRX4 forum just flipped their arm 180* and added a single y harness.
12-13-2019, 05:00 PM | #22 | |
Quarry Creeper Join Date: Feb 2008 Location: US
| Re: Reverse servo polarity? Quote:
I got a 7px for Christmas so I’ll soon have each diff on its own channel | |
12-13-2019, 05:02 PM | #23 |
| Re: Reverse servo polarity? This is what I was thinking at first some way to simply switch the direction. I figured there way an easy mechanical solution. I’m just so afraid to mess with these tiny servos cause they have quite the reputation for being super fragile. I think if the endpoints are set, make sure they aren’t hung half engaged and don’t screw the horn without needle nose grip they should be fine
12-14-2019, 04:41 PM | #24 | |
Rock Crawler Join Date: Jan 2019 Location: Calgary
Take a 1" or so female end of a servo extension and solder it along side the input of the signal reverser. Match the wire colors up, you'll end up with a "Y" built into the servo reverser. Now you plug in the signal reverser input lead as normal. The servo you don't want to reverse plugs into the new female servo extension you soldered onto the input side and finally, the servo you do want reversed plugs into the signal reverser output. | |
Reverse servo polarity? - Similar Threads | ||||
reverse polarity? | MacCrawl | Electronics | 5 | 05-06-2015 09:01 PM |
Hello accidentally did reverse polarity | jacobismynickname | Electronics | 6 | 03-25-2015 11:38 PM |
Can I reverse polarity on a Servo?? | savagefromthesprings | Electronics | 11 | 09-07-2009 10:40 AM |
REversing Servo Polarity ? ? ? | chivas72 | Newbie General | 10 | 02-27-2007 11:45 AM |
Reverse Polarity on Integy 55t | Trikster | Electronics | 2 | 08-03-2006 01:22 PM |
