01-01-2020, 09:49 AM | #1 |
Rock Stacker Join Date: Nov 2019 Location: uk
| HW 1060 Should i buy?
About to order a GS02 Bom. I can not see this model being pushed hard. I am going to run brushed, 35t motor. I have had good luck with the HW 1060 in several Tamiya models BUT not crawlers. Would it be ok to run the 1060? The 1080 is double the cost apx. |
01-01-2020, 09:50 AM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: HW 1060 Should i buy?
1080 all the way You get the program card with it and it's the best ESC Sent from my Pixel 2 XL using Tapatalk |
01-01-2020, 09:58 AM | #3 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
The 1060 is Ok in a basic trail truck I have a couple but the 1080 is the way to go for a crawler on a budget, it works great and has lots of tuning options, the 1060 is very limited in tuning options.
01-01-2020, 12:26 PM | #4 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
1060 makes a good cheap winch controller as well, can even de-case it and paint with liquid tape.
01-01-2020, 12:40 PM | #5 |
Pebble Pounder Join Date: Aug 2019 Location: Redlands, CA
1080 or 880, both programmable, which for me is a deal maker. Cheers.
01-01-2020, 12:48 PM | #6 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
If you are running an external BEC you can probably get away with either. If you are counting on the BEC circuit in the ESC itself the 1080 would be the better choice, especially if running a high torque servo, multiple servos, or both.
HW 1060 Should i buy? - Similar Threads | ||||
Hobbywing 1060 or 1625 as winch controller | treadway47025 | Electronics | 6 | 08-27-2019 07:11 AM |
WP-1060 dragbrake shutting off and on | MrBlank | Electronics | 4 | 11-24-2017 11:27 AM |
hobbywing quicrun 1060 problem | Blowout | Electronics | 18 | 12-01-2016 10:35 PM |
Hobbywing 1060 has no failsafe?! | QuesoDelDiablo | Electronics | 20 | 11-25-2016 12:39 PM |
Dual Hobbywing 1060 setup? | Desmo | Electronics | 0 | 06-23-2016 03:06 PM |
