Thread: 3s 11.1v Lipo - Voltage Telemetry showing 11.5v
Old 01-03-2020, 08:05 PM   #1
Default 3s 11.1v Lipo - Voltage Telemetry showing 11.5v
I've installed a voltage tap on my truck and the value I'm getting off a 3s 11.1v lipo is 11.5v. How could this be? Very confused here.
Sent from my SM-N976V using Tapatalk
RCTechGuy is offline   Reply With Quote
Old 01-03-2020, 08:11 PM   #2
Default Re: 3s 11.1v Lipo - Voltage Telemetry showing 11.5v
It's per cell, the full charge will be 4.2v per cell, the storage will be about 3.7v per cell and the low voltage cutoff will be 3.2v per cell.
For a 3s:
4.2v x 3 = 12.6v
3.7v x 3 = 11.1v
You will get different readings while it's draining.
Sent from my Pixel 2 XL using Tapatalk
Jboucher is offline   Reply With Quote
Old 01-03-2020, 08:37 PM   #3
For a 3s:
4.2v x 3 = 12.6v
3.7v x 3 = 11.1v
Thanks for the information. What I am confused about is that I'm getting a reading of 11.5v. How is it able to put out more that 11.1v per cell?
Old 01-03-2020, 08:45 PM   #4
I'm using an FPV setup for my bomber. The goggles, the camera OSD and the LiPo monitor won't show the same voltage. I guess it's all the wiring and resistances?
Old 01-03-2020, 09:01 PM   #5
It's not putting out 11.1 volts per cell, it's reading the entire pack, which is 3 cells. Read the first reply you got, explains everything.
Xx Losungen xX is offline   Reply With Quote
Old 01-03-2020, 09:03 PM   #6
Thank you.
3s 11.1v Lipo - Voltage Telemetry showing 11.5v - Similar Threads
Anyone using telemetry for battery voltage? ajw068 Newbie General 10 11-18-2015 01:06 AM
Keeps showing low voltage Dcaprilia Newbie General 5 09-21-2011 12:35 AM
What voltage lipo? 7.4v enough? Crawl_Before_Walking Losi Mini-Rock Crawler 10 02-06-2010 02:43 AM
Lipo Voltage treday619 Electronics 2 05-10-2009 01:26 AM
DX3S Voltage Telemetry with SR3300T ErichF Electronics 2 02-20-2009 08:15 AM
