05-17-2020, 02:28 PM | #1 |
Newbie Join Date: Mar 2020 Location: Palm Beach County Florida, US
| Battery Charger
Knowing how dangerous these lipo batteries can be, I wanted a secure way to charge them around the house. I used a metal ammunition can. I'm going to cover the hole i made some fire retardant fabric. What do you think? I already had a 3S battery explode on me in the empty can. It held up really good. Sent from my SM-N975U using Tapatalk |
05-17-2020, 03:03 PM | #2 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Battery Charger
Nice home made Bat Safe! |
05-19-2020, 10:13 AM | #3 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Battery Charger
Overall, I really like it. Clean design, really good install/build. I'd have a couple concerns if it was mine though- How well is it vented? You should have at least a couple 1/2" holes in there for venting. If you ever do have a full blown LiPo explosion/fire, the rapid expansion of gasses can turn a sealed ammo can into a very powerful pressure bomb very quickly. Fire retardant fabric on the on the outside of the vent to direct/control the venting seems like a really good idea. That pigtail harness in the can scares the snot out of me. So many exposed connectors that could short out in the can. You mentioned that you've already had an incident - any chance it was related to that pigtail short circuiting? I'd recommend protecting or removing any leads you're not actively using. |
05-19-2020, 11:04 AM | #4 |
| Re: Battery Charger
MAYBE DON'T PLUG A LIPO INTO THAT HARNESS WHILE THAT DEANS PLUG IS AN INCH AWAY FROM CAUSING AN ELECTRICAL SHORT AGANST YOUR METAL AMMO BOX AND CAUSES A FIRE! Sweet Jesus are you still ok.... Put a Freaking cover on that Deans/T plug for the love of all that is holy! If a lipo battery ignites in a sealed can its basically a bomb. You need some venting so the pressure can't build up. Just remove like half of that seal around the top. And a temp sensor for that charger is like $5 then it can auto shut off, since were talking safety. |
05-19-2020, 09:36 PM | #5 |
| Re: Battery Charger
The bottom pictures of the damaged can is the one that suffered a battery ignition. The battery was 6 weeks old and it had a bad cell. It was totally sealed in the can. The hard plastic shell popped open on the battery in my house on my dining room table. Thankfully I was sitting there to hear it. I placed it in the can and put it out front, 5 minutes later it went off. The can vented itself through the seems at two locations. But as you can see, it held it together very well. I like the idea of vents, I was thinking of putting a fire retardant fabric on the inside though. The pig tail came with the charger and honestly never gave a thought to the potential of it coming in contact with the can during the charging. In my defense the battery wasn't actually charging, just hooked up for the pictures. I will be covering them in future uses. That's the only battery that I use that pig tail for. Which will be changed tomorrow. I didn't know about the temp sensor and would like to get that as well. I'll have to search for it. Thank you for the advice. I will make the adjustments. I am new to the hobby and trying to be as safe as possible. Thanks again!! Sent from my SM-T820 using Tapatalk |
05-20-2020, 01:57 AM | #6 |
| Re: Battery Charger
This is what is left of that battery and the burn marks on the cement and rocks Sent from my SM-N975U using Tapatalk |
05-20-2020, 03:18 AM | #7 |
Pebble Pounder Join Date: Jun 2018 Location: New Zealand
| Re: Battery Charger
Yes, definitely make sure it's not sealed https://youtu.be/CnNId0mDnBo |
05-20-2020, 11:59 AM | #8 |
| Re: Battery Charger |
05-20-2020, 03:31 PM | #9 | |||
I wanna be Dave Join Date: Jan 2006 Location: Corruptifornia
| Re: Battery Charger Quote:
Agreed, not a fan of multi plug harness like that, they are all 'live' and can short out at any time, plus I don't need them all. I've got several dedicated pigtails. Quote:
X2, also the wires outside the can are insulated buy laying across the exposed metal pass-throughs, always insulate everything! Quote:
Yep. | |||
05-20-2020, 05:34 PM | #10 |
| Re: Battery Charger
I just seen a video showing them using regular drywall to insulate the can. Sent from my SM-T820 using Tapatalk |
05-20-2020, 05:43 PM | #11 |
| Re: Battery Charger
The holes that the positive and negative wires go through the can are insulated with rubber grommets. Are you referring to the actual gold plugs. I suppose I could cover them with some heat shrink. Sent from my SM-T820 using Tapatalk |
05-20-2020, 05:44 PM | #12 |
Newbie Join Date: Dec 2018 Location: Canada
| Re: Battery Charger
Glad I read this thread and watched the video posted. I quickly removed the seal from the ammo can. Lipos scare the shit out of me.
05-20-2020, 06:15 PM | #13 | |
__________________________ Handy gearing spreadsheet | |
05-20-2020, 07:54 PM | #14 |
Newbie Join Date: Feb 2020 Location: Santa Cruz
| Re: Battery Charger
Can you make me one? |
Battery Charger - Similar Threads | ||||
Battery/Charger ?? NiMH's w/ NiCD Charger ? | 56effie | Electronics | 5 | 10-31-2014 01:23 PM |
UK Version please - LOSB0862 Battery Charger & Battery. | newth | Losi Micro-Rock Crawler | 7 | 05-26-2010 01:38 AM |
*No Battery* message w/battery connected to charger? | pantablo | Electronics | 5 | 03-19-2008 11:06 AM |
