08-11-2021, 05:28 PM | #1 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| Will my setup work? HH CM 11t Magnum, BR mini, and 4S.
Good afternoon RCC! I recently picked up a BR mini and Crawlmaster Magnum 11t. I know the mini can handle 4S but can the Magnum? Also I'll be running a very conservative 9T pinion and 56T spur gear. Will heat be an issue with 4S? Thanks! Sent from my SM-N986U using Tapatalk |
08-11-2021, 06:14 PM | #2 |
| Re: Will my setup work? HH CM 11t Magnum, BR mini, and 4S.
Yep, I did a 4S build a while back and emailed Holmes to ask basically this since they don't always list a voltage range. This was their answer: 'As long as you watch gearing any of our motors can handle 4s' I actually had them make a 20T Crawlmaster magnum for me to slow it down, I also geared down which was probably all I needed to do. Maybe Just check temps on the first runs to be safe. |
08-11-2021, 06:32 PM | #3 |
Oh lord. Now I regret getting a 11T lol! Sent from my SM-N986U using Tapatalk |
08-11-2021, 07:02 PM | #4 |
Well maybe gear down more if you can. It looks like the 20T motor is now something they stock.
08-12-2021, 04:46 AM | #5 |
I run a 10t 550 crawlmaster only on 4s. Geared 100:1 92t pinion, 9t spur maybe it gets warm. But nothing hotter then dinner. This is in a big 12lb hotrod too. The 11t will produce more power, and you can easily drop to a 3s battery if it gets warm. Sent from my SM-N986U using Tapatalk Last edited by Voodoobrew; 08-12-2021 at 04:54 AM. |
08-27-2021, 10:26 AM | #6 |
Found a Crawlmaster Magnum Stubby 16T stashed away on an internet hobby shop shelf. Gonna end up selling the 11T.
Will my setup work? HH CM 11t Magnum, BR mini, and 4S. - Similar Threads | ||||
Will this 2.2 setup work? | shhuskins | Axial Capra | 2 | 12-10-2019 10:11 PM |
Would this setup work? | AUSyTyIN | Axial XR10 | 35 | 03-31-2011 01:48 PM |
Will this setup work? | Jedda | Axial XR10 | 11 | 01-09-2011 01:52 AM |
will this setup work? | 666crawler | Electronics | 7 | 06-16-2008 10:01 PM |
Mini Revolvers 22 Magnum | John Deere | Chit Chat | 22 | 04-30-2007 08:10 PM |
