Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: Enduro, here we endurgo!
Old 07-13-2019, 09:31 PM   #1
Default Enduro, here we endurgo!
Well after a neighbor (I’ve never met) a few houses delivered my boxes with over $600 in items to me, it’s time for another build. Damn USPS. Bodie and bumpers are still in question. Any input would be greatly appreciated. Pics help too.
Fishcharger is offline   Reply With Quote
Old 07-13-2019, 09:38 PM   #2
Default Re: Enduro, here we endurgo!
It's gonna be fun!
soze is offline   Reply With Quote
Old 07-13-2019, 09:48 PM   #3
Go Buckeyes!
B-MOW71's Avatar
That’s a nice neighbor to have!
Can’t wait to see more!
B-MOW71 is offline   Reply With Quote
Old 07-13-2019, 09:51 PM   #4
Ha yep. I would have done the same for them, after I built it if course;)
Old 07-13-2019, 09:56 PM   #5
Progress. Digging the “hard” plastic. Wasn’t sure if it was worth it, but glad I went with them.
Old 07-13-2019, 09:59 PM   #6
Put your stock front batt box mount out back as a brace, looking fine!!
Hang up and Drive
mikemcE is online now   Reply With Quote
Old 07-13-2019, 10:04 PM   #7
Hang up and Drive
Oh hey great idea!! Consider it done. Question in regards to overdrive. I understand what it does, and the benefits. But not how it works exactly. Are the gear ratios shown here referencing transmission gears, or spur and pinion gears?
Old 07-13-2019, 10:11 PM   #8
Transmission gears
HumboldtEF is offline   Reply With Quote
Old 07-13-2019, 10:20 PM   #9
Originally Posted by HumboldtEF View Post
Transmission gears
Copy that thanks.
Old 07-13-2019, 10:23 PM   #10
CODYBOY's Avatar
If you look at the tranny, one set of stacked gears run the front and the other stack drives the rear. So when your changing the set of gears in just one stack your changing the ratio to the front only to over drive it. Hope all that makes sense!!!
Ernie
CODYBOY is offline   Reply With Quote
Old 07-13-2019, 10:29 PM   #11
Originally Posted by CODYBOY View Post
If yo look at the tranny, one set of stacked gears run the front and the other stack drives the rear. So when your changing the set of gears in just one stack your changing the ratio to the front only to over drive it. Hope all that makes sense!!!
Ernie
Ah yes that does break it down to where I can understand it. Haven’t gotten to the tranny yet, but am I correct that it didn’t come with anything but the “stock” ratio gears? Also, if one was to choose the ratio for the best performance for low and slow rock crawling, which ratio is best?
Old 07-13-2019, 10:35 PM   #12
It comes with the 2 overdrive options, they dont include the 1:1 gear. In my opinion more overdrive is better for crawling, so the 11% gearing.
Old 07-13-2019, 11:00 PM   #13
Sweet thanks, that’s what I’m going with then
Old 07-14-2019, 10:55 AM   #14
A couple more questions for you. Do the spur and pinion gears effect overdrive ratios at all? Instructions note using a 18t pinion gear. In trying to accomplish low and slow crawling, would you recommend going ahead and sticking with a 18t, or would a 17t or 16t or even lower tooth count be what I’d want to do?
Old 07-14-2019, 11:25 AM   #15
The Spur/Pinion gear can't affect an overdrive. The pinion/spur gear send torque to a transfer case (center diff) that then sends torque to both the front and rear diffs that distributes to the wheels. An overdrive is done either in the transfer case (center differential) and/or in either or both the front and rear diffs.
stormridersp is offline   Reply With Quote
Old 07-14-2019, 11:44 AM   #16
Ah copy that thanks. Pinion gear recommendation?
Old 07-14-2019, 12:03 PM   #17
18t is stock with 16t(1850kv) on 2s
What motor(kv) and battery using?
Hang up and Drive
Old 07-14-2019, 12:07 PM   #18
Hang up and Drive
HH 13t 540 crawlmaster. 2s lipo
Old 07-14-2019, 12:17 PM   #19
Thats what I’m going to run, Im going to start with a 17 (as I have 16,17,19,20)
Wheelspeed will be my key, might not have enough with a 17
Hang up and Drive
Old 07-14-2019, 02:13 PM   #20
Lol, is it me or is this the biggest receiver box ever. Well picked up the 66’ Ford Bronco. So going with an 11.8” WB. Hoping it’s a good look for the Enduro. Front bumper ideas? I do like the bumper shown in the pic there, not sure which brand/model it is though. Also in the pic showing the rear there’s no bumper. That due to how high the body is going to sit? I would like a rear bumper but not sure if there’s one that has an option to have it raised high enough to meet the back of the body.
Enduro, here we endurgo! - Similar Threads
What I'm doing to my ENDURO! CODYBOY Element RC 1/10 Enduro Trail Truck Sendero 98 04-10-2020 08:37 PM
Enduro Funduro Old n ratty Element RC 1/10 Enduro Trail Truck Sendero 3 07-07-2019 01:43 PM
kmc enduro? flat out Tires and Wheels 18 11-18-2012 10:59 AM
The 1/8 Wonder Enduro Race The Cow Non Crawler RC's 5 09-22-2010 03:47 PM
Enduro Cross twisted Chit Chat 7 02-05-2008 08:22 PM
