10-22-2019, 07:39 AM | #1 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
| Shorter shocks?
So far the only issue I've had with my enduro is the ride height. I'd like to get it at least 10 to 15mm lower. I like the stock shocks, they look scale, are very smooth and have good springs available. I'm pretty sure these are the same diameter as the shocks from the re-production RC10 worlds car (have one I play with a lot). I'd love to find some stock fronts from a worlds car but talk about hard to find. I've got a bomber with the slash F/R proline shocks that are also awesome but it looks like the small scaler version in grey has been discontinued. I don't really care for the bright blue of the replacement versions either. Are there any other small scale quality options out there? |
10-22-2019, 07:41 AM | #2 |
Newbie Join Date: Sep 2019 Location: Clarksville
| Re: Shorter shocks?
You can do the pen spring mod to these shocks or add a little nitro tube on the shock shaft inside the body to achieve the ride height. Sent from my Phone using Tapatalk |
10-22-2019, 11:04 AM | #3 |
| Re: Shorter shocks?
I'd rather shorten the bodies and shafts to still get full up travel at the right time. I like the shock on a crawler to bottom before anything on the chassis or axles makes contact.
10-22-2019, 11:24 AM | #4 |
| Re: Shorter shocks?
I have full up travel. You out the pen spring in between the piston and the base of the shock body on the shock shaft. The shock works the same as it would if you were to shorten the shaft. Sent from my Phone using Tapatalk |
10-22-2019, 12:22 PM | #5 |
| Re: Shorter shocks?
I understand what you are saying and was doing that 10 years ago. What I'm looking for is shorter total length shocks. Not just travel restriction of the stock shocks. I'm aware of the travel limitations of the stock suspension but I'm looking to lower the ride height of the whole truck. That entails raising suspension mounting points ie, track bar, steering "box" and all the other associated attachment points. Looking to do something just short of c-notching the stock frame. |
10-22-2019, 12:36 PM | #6 | |
| Re: Shorter shocks? Quote:
Sent from my Phone using Tapatalk | |
10-26-2019, 09:52 PM | #7 |
Rock Stacker Join Date: Aug 2019 Location: SoCal
| Re: Shorter shocks?
I picked up some Shock Keys by IE RC Not installed yet but I am planning to do same. My 4runner Enduro runs on 100mm shocks, bumper clearance is beutiful but I bet if i lower ride height 5mm and increase up travel by 5mm, ill have the sweet spot. |
01-17-2020, 08:35 AM | #8 | |
Pebble Pounder Join Date: Dec 2005 Location: lawrenceburg
01-17-2020, 08:40 AM | #9 | |
01-17-2020, 09:00 AM | #10 | |
Very nice. I was looking at bpc parts before i found this thread. I searched bpc and this popped up. | |
01-17-2020, 09:20 AM | #11 |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
| Re: Shorter shocks?
Incision will be releasing 80mm shocks soon. They just started putting them on the new VS4-10 ultra. Sent from my iPhone using Tapatalk |
Shorter shocks? - Similar Threads | ||||
Ax10 shocks - can I get a shorter body? | stimpy | Axial AX-10 Scorpion | 14 | 02-05-2016 10:15 AM |
Shorter shocks? | humanmachinehead | Losi Micro-Rock Crawler | 3 | 08-20-2011 11:21 PM |
TLT Shocks: Shorter Shafts? | Tommy R | General Crawlers | 5 | 04-26-2011 03:12 PM |
Limiting Long shocks = Shorter Shocks? | Captain Midnight | Venom Creeper | 2 | 04-10-2010 01:53 AM |
Are the losi shocks shorter than stock shocks ?? | im2tall | Venom Creeper | 3 | 02-05-2010 12:33 PM |
