11-12-2019, 04:58 PM | #1 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
| Panhard Bar turned 90*?
Is anyone out there 3D printing or brazing up a mount for the panhard bar that would turn the frame mount 90*? I want to raise mine a bit and prefer the rod end to be turned to pivot around the ball and not perpendicular to it. If I can't find anything shortly I'll try to braise something up with sheet metal but thought I'd see if the 3D printer guys had made anything yet. |
11-12-2019, 05:00 PM | #2 |
| Re: Panhard Bar turned 90*? |
11-12-2019, 09:49 PM | #3 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
I haven’t seen one but now that you mention I hope we see one, I can understand the preference for the pivot motion. Maybe SSD can come through with this one on their panhard mount. |
11-13-2019, 02:57 AM | #4 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: Panhard Bar turned 90*? I stayed with stock style for the panhard mount as it works fine. Also the panhard has a bent rod end which could ruin the geometry if rotated 90 degrees. You would need to change to a straight rod end on the frame mount end.
11-13-2019, 03:56 AM | #5 |
My pan hard bar isn't bent?
11-13-2019, 05:39 AM | #6 |
11-13-2019, 05:40 AM | #7 |
I see. Mine lost the threads in the stock rod ends and I went to traxxas ends.
11-13-2019, 09:36 AM | #8 |
I turned the panhard on both of the versions I made. V1 V2 |
11-13-2019, 10:27 AM | #9 |
11-13-2019, 01:56 PM | #10 |
I really like it. I especially like the upper pic but not sure if I could get the mount to the frame on there with just my map gass setup.
11-14-2019, 02:52 AM | #11 |
Ok so you moved it over to account for the bend or because you had to make new fixing point?
11-14-2019, 06:24 AM | #12 |
| Re: Panhard Bar turned 90*? Moving the panhard mount over was a combination of leaving space for the stock shock tower to attach and keeping the panhard as close as possible to the stock position. The bend in the Element rod ends is pretty mild so they operate well within their range of motion when turned 90* for this purpose.
12-06-2019, 08:10 AM | #13 |
I ended up making this. Not turned 90* but raised enough to use straight links I have now put quite a bit of miles on this setup and really like it. No breaks and plenty of articulation with my shorter shock setup. Last edited by terrible; 01-03-2020 at 08:25 AM. |
05-10-2020, 12:40 PM | #14 |
Newbie Join Date: May 2020 Location: Switzerland
Just joined the crowd and saw your post. If you have not yet made your mod, this part might serve your purpose. It worked for me: https://www.teamraffeeco.com/aluminu...n-metal-164121 |
05-17-2020, 08:56 AM | #15 |
| Re: Panhard Bar turned 90*? Ended up making this. |
Panhard Bar turned 90*? - Similar Threads | ||||
Panhard bar | T4rscott | Axial SCX-10 | 3 | 07-27-2015 10:28 AM |
Panhard bar | Lemonlegs28 | Axial SCX-10 | 23 | 07-12-2013 01:59 PM |
panhard bar | rezz | Axial SCX-10 | 5 | 03-26-2013 10:04 PM |
Panhard bar? | Cole82 | General Crawlers | 18 | 09-17-2005 09:18 AM |
