03-13-2020, 11:33 AM | #1 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Codyboy's IFS Portals Truck
At first I wasn't going to make a thread for my IFS truck, there are plenty already! Way back when I first ordered my IFS kit I mentioned that I may check into marrying SSD portals to the kit. So this is what I came up with. Now to show you how easy it was to do. Anyone with a drill or press can do it! Intersted??? |
03-13-2020, 12:05 PM | #2 |
| Re: Codyboy's IFS Portals Truck
I am interested... I was looking at the SSD portals for the UMG10, but curious how it works with the IFS. Is the width still the same? It looks much wider in your photo.
03-13-2020, 12:22 PM | #3 | |
| Re: Codyboy's IFS Portals Truck Quote:
Ernie | |
03-13-2020, 12:33 PM | #4 |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
| Re: Codyboy's IFS Portals Truck |
03-13-2020, 12:33 PM | #5 |
Pebble Pounder Join Date: May 2017 Location: Livin in SL,UT
Whoa!! That is sweet!! Nice work Ernie!! |
03-13-2020, 12:41 PM | #6 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Very cool! Glad this worked out and can’t wait to see more of it. SSD Portal in the rear? Any thoughts on a body? Also, mind if I share this on bookface? Last edited by Topher Builds; 03-13-2020 at 12:49 PM. |
03-13-2020, 01:31 PM | #7 |
RCC Addict Join Date: Jan 2009 Location: Bend
Ernie, this is rad! Apparently I need to actually get on the forums and do some browsing once in a while. I'm missing all kinds of cool stuff. Sent from my SM-S767VL using Tapatalk |
03-13-2020, 03:03 PM | #8 |
Does it it change the track width?
03-13-2020, 03:26 PM | #9 |
03-13-2020, 05:15 PM | #10 |
Doh. Dummy me for scanning and not reading. Thanks.
03-13-2020, 06:09 PM | #11 | ||
| Re: Codyboy's IFS Portals Truck I guess, just think people get tired of seeing "Codyboy" all the time. Thank you young man! As always I can't leave a stock set be! Quote:
I do it all the time, but I can blame mine on old age. Ok, I want to check a few more things out before I showed you guys how I did it. I started with a new builders chassis and the IFS kit. I already had the SSD front portal kit on hand. Here is how it looked before I started. So I pulled the assembled IFS kit off the truck so I could get to the diff. Because the portals have two gears they will change the rotation direction on the axle. The cool thing with this kit is you can switch the rotation of the diff by flipping the ring gear! That takes care of the direction change!!! With everything apart I stated with the dog bone drive axle and one of the portal gears. ( I used this same process when I built the offset front portals for my SSD Trail KIng) I move over to my vice and started filing flat spots on the hub end of the axle. Slow and steady and keep checking until the gear slides onto the axle. Next I needed to figure out how to get the axle to play nice inside the portal housing. First thing I figured out was the axle threads were smaller than the 5mm ID hole in the bearing. This one took me a few hours to figure out, (remember I'm 70 and my thinker doesn't process as quickly as some of you young whippersnappers! Finally the light went on!!! I threaded a nut onto a old rear axle shaft and off to the lathe. I know, most of you don't have a metal lathe. But you could achieve this with a drill or drill press and a file and or grinder. Last edited by CODYBOY; 03-15-2020 at 08:26 PM. | ||
03-13-2020, 06:24 PM | #12 |
Very cool Ernie! This definitely has piqued my interest. Subscribed
03-13-2020, 06:40 PM | #13 |
Next was to figure how much I should cut off the axle/drive shaft. Axle cut and bearing sleeve installed. Now we are ready to see if everything fits with no problems. Came up with a little binding on the mount for the lower arm. One nice thing is the SSD portal is alum so grinding in this area went well, lots of material to work with. I used a permanent marker to cover the silver color. And there you have a nice clean setup, I didn't have to change anything on the a-arms lengths. And back to this photo. If you have a problem making the bearing sleeve I sure you could convince Codyboy to help you out!!! Or I could do a bolt on kit for you! There you go, have fun. Ernie Last edited by CODYBOY; 03-13-2020 at 06:45 PM. |
03-13-2020, 07:23 PM | #14 |
Yes sir, snow just started rolling in. Like, just now. Shoot me a PM later and we'll swap numbers again. Sent from my SM-S767VL using Tapatalk |
03-13-2020, 09:15 PM | #15 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
03-13-2020, 09:25 PM | #16 | |
Forgot to ask, how’s the steering and shock travel with this set up? I see what you did there. Quote:
I know when I was new I had a hard time keeping up with what you were doing but as I learned more I continued to get more and more impressed with more than just the way the trucks looked. Please keep it up Ernie | |
03-14-2020, 11:04 AM | #17 | |||
I really hope that if any one out there doesn't understand what or how I'm doing something would ask for more info, and thank you for the kind words. It is always about passing it forward! Ernie Sway bar design. I came up with an easy add on to a IFS rig. This is a Dlux sway bar I've had for several years. Here is a updated version. https://dluxfab.com/#!/Sway-Bar-Wrai...tegory=6232188 So I added some parts from one of my old goody box. along with Erik's kit and came up with this. And just a little note, I used the existing holes in the frame rails. I started by adding a SSD Diamond axle kit, next I flipped over the link/shock mount, this helped in not having to stack the link, shock and connecting link all on the same mounting location. And no to binding on the shock!! Everything is tight but it is all free moving. Everything clears on the body! And tires and wheels fit fine. Thanks for looking, and as always questions are welcome! Ernie Last edited by CODYBOY; 03-14-2020 at 11:25 AM. | |||
03-14-2020, 12:00 PM | #18 |
anyone figured out a sway bar setup for the front IFS?
03-14-2020, 01:44 PM | #19 |
| Re: Codyboy's IFS Portals Truck Looks to me that you could use the mounts on the front of the diff case and run your piano wire out and bend to match the holes on the back side of the lower a-arm. Use link mounts and threaded material to attach wire to lower a-arm. But I bet knowing your skills you already figured out that part out. We did it for years when we were racing carpet and dirt. Ernie |
03-14-2020, 02:56 PM | #20 | |
Codyboy's IFS Portals Truck - Similar Threads | ||||
Modded Tundra Element IFS w/portals | Rock solid | Element RC 1/10 Enduro Trail Truck Sendero | 29 | 11-28-2023 10:51 AM |
Ifs foff truck | 450matt | Formula Offroad | 4 | 12-07-2014 07:57 AM |
portals for scale or a comp truck? | d-fly | General Crawlers | 0 | 06-21-2008 10:09 PM |
